11-01-2017, 10:15 PM | #1 |
1949 Mercury Coupe - Door Lock Rod
The inner door knob (that be pushed down or pulled up) has a rod that attached to the mechanism inside the door.
Anyone have a description or picture on how to attach the bent rod? I know it lowers through the hole atop the door. I cannot seem to attach it to the hole at the mechanism inside the door. I just don't get it. Thanks!
Matt Allyn 1932 Ford Roadster / 1949 Mercury Coupe / 1949 Harley Davidson "45" / 1957 Cadillac Eldorado Biarritz Convertible / 1957 Lincoln Premiere Convertible / 1959 Lambretta TV175 / 1962 Sunbeam Alpine Convertible / 1962 Chrysler New Yorker Station Wagon / 1962 Chrysler 300H / 1962 Chrysler 300 Sport / 1964 International Travelall / 2015 Tesla Model S |
11-02-2017, 04:12 AM | #2 |
Re: 1949 Mercury Coupe - Door Lock Rod
It is installed from inside the door before any door panel or garnish molding is installed.
It is installed into the hole while being held horizontally, then lifted to its vertical position. It is not lowered through the hole atop the door. It may be possible to position it forward enough through the top of the door (without garnish molding in place) to get it past the retainer tab.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 11-02-2017 at 07:55 AM. |
11-02-2017, 05:54 PM | #3 |
My Door Panel and Garnish Molding are still off the door. I now see that I may have to unscrew the latch from the door... To have the latch LOW enough... So I can thread the rod UP through the door hole... AFTER I attach it to the latch All makes sense! Thank you!
