09-29-2023, 09:55 AM | #1 |
2x2 fuel line question
I currently have 2x2 intake with 2 strombergs attached. I have the back one blocked off. Is there a way to run fuel line to both carbs and block off the back so that it looks like they both are working?
09-29-2023, 11:40 AM | #2 |
Re: 2x2 fuel line question
Fill up one of the fittings with solder.
09-29-2023, 01:17 PM | #3 | |
JC ..... Even if you get the fuel delivery situation ironed out (which ain't no BIGGIE), you're gonna hate the way that performs on your engine. With MOST manifolds, the front carb feeds every other cylinder in the firing order. The rear carb then takes care of the remainder of the cylinders in their respective firing order. But what do I know? Coop . |
09-29-2023, 01:40 PM | #4 |
