Old 02-04-2019, 03:04 PM   #21
Smooth_One
Smooth_One's Avatar
Default Re: Installed battery cutoff switch today.
Originally Posted by Russ/40 View Post
The amount and length of your cabling makes the gauge of 4, potentially more problematic. In the end, you will do it your way, but, you did ask for opinions.
Do you think the 4 gauge cable would get warm after a while or your just talking about low amps for the size?
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-04-2019, 03:12 PM   #22
rrich1
rrich1's Avatar
I obviously didn't install mine but mine is located under the dash.
Sent from my Pixel XL using Tapatalk
rrich1 is offline   Reply With Quote
Old 02-04-2019, 04:05 PM   #23
Smooth_One
Smooth_One's Avatar
Looks good. I just don't like seeing the switch on the other side of the firewall.
Isaiah B.
Old 02-04-2019, 04:26 PM   #24
Russ/40
Russ/40's Avatar
I don't think that would be an issue. The use of 4 gauge wire is perfect for 12 volts, but becomes current limiting at 6 volts when cranking an engine to start. Beyond starting, the 4 gauge is OK for everything else.
You may be just fine starting, but as soon as age starts its process of oxidation it will creep up on you and some day it'll be cranking too slow and you'll be wondering why. If you stay with the 4 gauge, just be mindful of the issue. Keep connections pristine.
Old 02-04-2019, 04:32 PM   #25
Russ/40
Russ/40's Avatar
Not familiar with seat mounting in a sedan, I don't know if you have a seat riser like in the trucks, rdstrs etc. The front of the seat riser just below your left leg would be ideal, as it is close to the battery, and minimal cabling would be needed.
By the way, I like your sedan. What is the story with it. History....
Old 02-04-2019, 11:14 PM   #26
Smooth_One
Smooth_One's Avatar
Thanks for the input!
My Tudor came from just north of Detroit from my father in-law. He’s owned it since 1962. He drove it a ton back then and then he bought a few more A’s and had one or two Model T’s so the Tudor got parked for around 30 years and hasn’t been touched til I got it.
Isaiah B.
Old 02-05-2019, 03:01 PM   #27
slammin
slammin's Avatar
I mounted mine thru the floor under the driers seat, using #2 copper wire. I also added another ground cable over to the tranny mount.
slammin is offline   Reply With Quote
Old 02-07-2019, 10:20 AM   #28
Cave
Cave's Avatar
Nice install Smooth_One! The PO installed the same one in my '31 coupe. To save opening the hood so often I fabricated an extension rod that reaches the switch and protrudes out a little under the hood (there was adequate clearance without having to modify the hood).
I drilled and tapped the switch handle to accommodate the eyebolt and put a dab of JBWeld (not shown) on it to keep it snug. I bent a 1/4" threaded rod - note: I ground off the threads before heating and bending, experience told me that threads sometimes tear through the stock when bent. Then I covered it with 1/4" shrink tubing to hide the threads. Finally one more stainless steel eyebolt to make an outside support.
Purists will balk, I'm ok, I drive it for me, not others.
Cave is offline   Reply With Quote
Old 02-07-2019, 10:43 AM   #29
Smooth_One
Smooth_One's Avatar
Attachment 387864
Attachment 387865
Attachment 387866
Attachment 387867
Attachment 387868
Very nice. Thanks for sharing! Simple but clean fab work there.
Isaiah B.
Old 02-07-2019, 10:47 AM   #30
Smooth_One
Smooth_One's Avatar
I did run another 4 gauge ground cable from a spot i cleaned down to bare metal on the frame and then to a clean spot on the bell housing. I'm also going to run another one on the passenger side in the same spots for peace of mind.
We''ll see how it works.
The starter spins waaaayyy faster with the ground attached! Very noticeable difference!
When I get some worn engine parts replaced I will replace all motor mounts and clean the frame to regain some lost frame ground.
Isaiah B.
Old 02-07-2019, 10:56 AM   #31
Jim M
Jim M's Avatar
I have mine under the hood instead of the cab. They both have pro's and con's...what ever works for you! Looks great!
Jim M is offline   Reply With Quote
Old 02-07-2019, 11:02 AM   #32
Cave
Cave's Avatar
What am I doing wrong... how do I get my jpgs to show without having to login?
Old 02-07-2019, 11:10 AM   #33
katy
katy's Avatar
When you log on, click on Remember me? Then you automatically "log on" when you access the site.
Old 02-07-2019, 11:21 AM   #34
Cave
Cave's Avatar
Yes, I understand that, but just casually browsing anyone can see Smooth_One's photos, mine you either have to click on the jpg name or sign in. There must be a set-up option I've missed.
Old 02-07-2019, 11:41 AM   #35
Russ/40
Russ/40's Avatar
Clever addition Cave!
Old 03-30-2019, 08:32 PM   #36
Steves46
Steves46's Avatar
[QUOTE=BillLee/Chandler, TX;1723380]Mine is mounted under the floor on a bracket I made from 1/8" aluminum, screwed to the bottom of the wood cross piece. I then made an extension to the shaft where the handle mounts so that the handle is just above the level of the carpet under the front edge of the seat. Yes, a hole drilled through the wood floorboard behind the steel cross member. Very unobtrusive and easily accessed.
With the switch there, I can easily disconnect the entire system from the battery (which I do as I exit the car).
Problems of concern that the switch being easily accessible address:
* A stuck starter switch ( have seen happen).
* Stuck brake light switch.
* Reverse drain through alternator when not running.
* Short behind the dash panel.
* Theft prevention.
* Forgotten headlights or turn signals.
(I'm sure there are others, I invite contributions. :-) )
Edit to add a picture showing the switch through floor board, no carpets installed at that time.[/QUOTE
With regards to the reverse drain to the Alternator, explanation please? I have one of these switches and also have an alternator...does this mean I need to shut off the switch every time I drive the car and stop somewhere like a car show? I had to get a jump start today and wondered if this could have happened
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 03-30-2019, 08:38 PM   #37
Bill G
Bill G's Avatar
Maybe his are external links rather than stored in the Ford Barn forum.
Old 03-31-2019, 11:44 AM   #38
Badpuppy
The alternator regulator draws a few milliamps at all times. Same for electronic cutout regulators and turn signal e-flashers. Shouldn't be a battery drain issue unless the car is parked for an extended period (weeks/months).
Old 03-31-2019, 01:09 PM   #39
wmws
At least you put the switch in the ground cable. So many put it on the hot side which leaves the part from the switch to the hot battery post exposed to shorting.
wmws is offline   Reply With Quote
