Old 09-18-2018, 04:36 PM   #1
GerryAllen
Default Transmission locked in Reverse
Before any of you die-hards rag on me about previous threads, have tried to search info.
Putting new rear end in car, got it ready for a test drive and transmission locked in Reverse. Have taken tower out and in again and still cant get it ti shift, any suggestions would help.
Gerry Birch Bay Wa
GerryAllen is offline   Reply With Quote
Old 09-18-2018, 04:49 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Transmission locked in Reverse
Long shot, but your detent springs may be too long, bottoming out and preventing the shafts from moving.
Old 09-18-2018, 04:50 PM   #3
Jacksonlll
Jacksonlll's Avatar
Put tower in a vice and make sure it shifts ok.
Old 09-18-2018, 07:00 PM   #4
Tom Endy
Tom Endy's Avatar
Hopefully you did not accidently drop a bolt down in the transmission while you had the tower off. They will hide back by the reverse idler gear, then when you shift into reverse they will jam up and do some damage.
Tom Endy.
Tom Endy is online now   Reply With Quote
Old 09-18-2018, 07:47 PM   #5
J Franklin
J Franklin's Avatar
With the tower off can you move the gear out of reverse?
Old 09-19-2018, 10:48 AM   #6
GerryAllen
thanks guys
Old 09-19-2018, 11:51 AM   #7
mollydog
You said you put a new rear end in the car then the trouble with being stuck in reverse. Was it a rebuilt rear? Did you rebuild it with a new ring and pinion? The ring gear can be installed on the wrong side of the pinion causing only reverse!
Just a thought.
Mollydog
mollydog is offline   Reply With Quote
Old 09-19-2018, 12:48 PM   #8
40 Deluxe
Just a thought.
Mollydog
Not quite. The car would move forward with the trans in reverse.
Old 09-19-2018, 02:21 PM   #9
figment
If the ring gear is installed on the wrong side you would have 3 speeds in reverse and 1 speed forward
figment is offline   Reply With Quote
Old 09-19-2018, 02:31 PM   #10
denniskliesen
denniskliesen's Avatar
Make sure your shifter hasn't jumped out of position between the forks.
denniskliesen is offline   Reply With Quote
Old 09-19-2018, 03:08 PM   #11
Jacksonlll
Jacksonlll's Avatar
I did this when I was 16. When we discovered what we did, I wanted to fix it before any of our friends came by, but my buddy insisted on driving it around the block in reverse. He did and we fixed it real fast. Never got caught by our friends.
Old 09-20-2018, 09:16 AM   #12
katy
katy's Avatar
Gerry Birch Bay Wa
Loosen off all the U joint housing bolts and see what happens
Old 09-20-2018, 10:01 AM   #13
GerryAllen
Keep the ideas coming, will work through them this weekend.
Gerry Birch Bay Wa
Old 09-20-2018, 10:38 PM   #14
GerryAllen
Thank you all, got it unlocked. Removed the tower, rocked the car back and forth while gently nudging on the aft gear and Walla it was free.
What a relief, thanks for your suggestions. New to Model A's, this web site and fellow club members really help us newbies with our problems.
Gerry
