11-01-2016, 12:12 AM | #21 |
Re: 283 Chevy Pistons For Model A Rods
keep in mind that a B motor is thinner in the valve area. They crack there often, and especially if someone thinks seats are a good idea, which they are not.
I would check with Jim B. 4.030 is kinda big. They are also way tougher to seal the rear main because of the pressure oiling
'31 180A |
11-01-2016, 05:01 PM | #22 |
tbirdtbird ---- Thanks for the information. As the motor was pressure tested I did not think there would be any problems with cracks in the case valve area. I feel like you that 4.030" bore is real risky. Can anything be done to help seal the rear main?
11-01-2016, 06:01 PM | #23 |
forever4 --- Thanks, for good news.
Still need to make sure a "B" block will handle 1.750" intake valves? Is 4.030" to big a bore on a "B" block? |
11-06-2016, 06:31 PM | #24 |
Does anyone know of a place to buy solid copper or hi performance composite style Model B head gaskets for a 4.030" bore?
11-06-2016, 09:49 PM | #25 |
Try Clark Copper Heat Gasket Company
clarkcopperheadgaskets.com
1965 Lotus Elan S2 1930 Model A Sport Coupe |
12-15-2016, 09:43 PM | #26 |
12-16-2016, 02:20 PM | #27 |
Are we talking about the head gaskets or 283 stile pistons?
On 283 stile pistons with correct model A pins, Pete's Machine 505-836-3110 4.030 & 4.060 head gaskets Dan Price 740-965-2515 |
