10-13-2022, 12:33 PM | #1 |
What would cause this?
Hey All,
One of the gentlemen that goes out with us on our weekly breakfast run has a 31 slant window Fordor with the squeakiest brakes on the planet. Yesterday, he finally pulled his drums and this is what he found with one drum. What would cause the grooving in such even spacing? Regards Bill |
10-13-2022, 02:35 PM | #2 |
Re: What would cause this?
Are the shoes new?
Are those grooves in the drum or just surface marks? |
10-13-2022, 04:59 PM | #3 |
The larger the area of contact between the lining and the drum, the better the brakes.
I bet this was someone's brain wave (fart) to increase the contact area and improve the brakes. He needs new drums and linings, IMO
10-13-2022, 05:30 PM | #4 |
Synch has it...............
the grooves are for cooling, when your A is rounding the corner at 90 mph. |
10-13-2022, 05:50 PM | #5 |
When I was a lad back in the 50's my dad bought a Desoto and the brakes squeaked bad. We noticed that all Chrysler products at that time done the same. He took it to the Chrysler garage and they put a table spoon of dry cement in each brake drum and it stopped the squeaking.
10-15-2022, 07:55 AM | #6 |
Bob Bidonde Last edited by Bob Bidonde; 10-15-2022 at 08:02 AM. |
10-15-2022, 09:26 AM | #7 |
I'll go with Synchro on this one.
10-15-2022, 09:44 AM | #8 |
What fool would ever think this was a good idea? Really? If it was for an attempt
to improve braking, you don't want a Model A. Maybe a 2022 car with anti lock brakes better suits you. Model A brakes are the best, they haven't leaked for 90 years! |
10-15-2022, 04:29 PM | #9 |
The Lockheed and Bendix brake designers left them flat on the face surfaces so that brake lining wear debris could be shed off. With grooves, the debris tends to get mashed into the bottom of the grooves where it would act a a sort of lubricant. This would reduce the friction which is needed for good braking.
The groove pattern appears to have been deliberate since its so uniform. I've seen plenty of grooves drums but not that uniform. |
