11-04-2019, 03:10 PM | #1 |
Engine I. D.
How can I tell if my engine is the original one that came from the factory? I have a 1949 Ford Custom with a 239 Flathead. The numbers on the heads are for a 51 Flathead but not sure of the block.
11-04-2019, 04:17 PM | #2 |
Re: Engine I. D.
Look on the left rear of the block, on the intake surface, there may be a date code stamped in it. Not all of them have it but that’s going to be the only way to get it close.
Go to Van Pelt’s website and they should have a breakdown of the codes. |
11-04-2019, 04:24 PM | #3 |
Re: Engine I. D.
There may or may not be a date code on the rear passenger side of the intake mount surface.
If there it could be as early as 1948.
11-04-2019, 04:25 PM | #4 |
Re: Engine I. D.
Found it http://myflatheadford.com/wp-content...7/01/date3.jpg
Ah, beat me to it, and I was wrong, it’s right rear. |
11-04-2019, 05:19 PM | #5 |
Re: Engine I. D.
1BA heads were used as replacements for the 8BA heads after the EAB heads came out. Mercury engines were 4-inch stroke 255 cid set ups. The only internal differences were the crank and the pistons. Cams also have markings but they are replaceable and the later replacement was the EAB cam shaft. Last edited by rotorwrench; 11-04-2019 at 05:27 PM. |
