Old 07-17-2013, 06:25 PM   #1
Kevinsrodshop
Kevinsrodshop's Avatar
Default Anybody mount a brake pedal switch on a 32 Ford with mechanical brakes.
I picked up one of these brake switches from Macs. Hoping I could make it work on a 32 Ford with mechanical brakes. Trying to find a mounting spot for it in the brake pedal area. Anybody do it before and can give me a pic?
Kevinsrodshop is offline   Reply With Quote
Old 07-17-2013, 09:03 PM   #2
jim1932
jim1932's Avatar
Default Re: Anybody mount a brake pedal switch on a 32 Ford with mechanical brakes.
It mounts to the top of the transmission. Easier if you pull floorboard. If I have a photo I will post it. Just did mine
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 07-17-2013, 09:09 PM   #3
jim1932
jim1932's Avatar
Go to the smugmug link in my signature, photo 188.
Old 07-17-2013, 09:11 PM   #4
Kevinsrodshop
Ok I see it in pic 188. Is that a spring attached to the end of the switch? How does the switch actuate? I'm confused
Old 07-17-2013, 09:21 PM   #5
Charlie Stephens
You need the correct 1932 switch and it will become obvious. Maybe you can find a picture on EBAY or in "The 1932 Ford Book".
Charlie Stephens
Old 07-17-2013, 09:26 PM   #6
jim1932
jim1932's Avatar
The spring on mine is messed up. It is supposed to attach to the end of the switch which mine does. The other end attaches to a washer with a hole in it on the pedal assembly. Picture 147 shows about where it is. Mine was incorrectly Hooked into the cotter pin. washer should be to the left of the cotter pin. There is a photo in the 1932 ford book, but I am away from home and can't tell you where.
Old 07-17-2013, 09:26 PM   #7
Kevinsrodshop
This gets me a little closer.
https://www.fordbarn.com/forum/showthread.php?p=547089
Old 07-17-2013, 09:30 PM   #8
jim1932
jim1932's Avatar
That's it. I am missing that part.
Old 07-17-2013, 09:36 PM   #9
Kevinsrodshop
This is turning into quite the learning experience lol
I honestly didnt know 32s came from the factory with brake lights.
Old 07-17-2013, 10:49 PM   #10
JimOH
JimOH's Avatar
Here is a picture of the correct switch, spring and clip.
JimOH is offline   Reply With Quote
Old 07-17-2013, 10:53 PM   #11
Kevinsrodshop
Ahhh now it makes sense. Thanks for that pic.
Old 07-18-2013, 02:22 AM   #12
ken ct
You GOT to be kidding?? ken ct usa
ken ct is offline   Reply With Quote
Old 07-18-2013, 09:10 AM   #13
jim1932
jim1932's Avatar
Make that brake light...... Only one typically.
Old 08-15-2013, 03:13 AM   #14
Keoki808
Keoki808's Avatar
more pics for you
Keoki808 is offline   Reply With Quote
