05-15-2019, 06:24 PM | #1 |
1937 ford pickup pilot bearing
I'am working on 85 hp 21 stud flathead installing and the new pilot bearing is thicker than the one took out, so it about 1/8!" Out from the crank is that ok or should I get one that sits even with the crank
05-15-2019, 08:02 PM | #2 |
Re: 1937 ford pickup pilot bearing
All the ones I've replaced were pressed in to the flywheel. Yours is in the crank?
05-15-2019, 08:25 PM | #3 |
All I've ever installed are in the flywheel.
05-16-2019, 07:48 PM | #4 |
