01-25-2011, 09:50 AM | #1 |
Steering column bushings(s)?
Guys is there one or two rubber surronded bushings inside the steering column? The exploded view in the Green Book shows only one but 2 came out of mine. Is there one high and one near the box? Thanks in advance.
John Mc Crystal Lake, IL '39 1/2 Ton Pickup '56 Lincoln Capri Hardtop '77 Lincoln Town Coupe |
01-25-2011, 10:29 AM | #2 |
Re: Steering column bushings(s)?
one only, a bushing down the shaft would do no good--replace yours with a bearing,like ford did later, sure makes the steering easier.
01-25-2011, 11:31 AM | #3 |
Instead of removing the old bushing, often times it is easier to drive the old bushing further down the shaft and then install the new bushing. That's how you end up with two. Alan is correct, I would replace the old bushing with the new bearing type. I see them listed on epay every once in a while. Good luck, Pat
01-25-2011, 01:09 PM | #4 |
Thanks guys.
01-25-2011, 01:45 PM | #5 |
Dan Brusegard makes a superior bearing unit for this application.
He's on Eagle Lake drive in Maple Grove , Minn. Reach him by e-mail at; dancb at comcast dot net. Ken |
01-25-2011, 02:26 PM | #6 |
