Old 10-12-2021, 11:08 PM   #1
RalphM
RalphM's Avatar
Default Interesting 8BA
I’ve had this engine for about 15 years, stored in the corner of the shop, and I kinda forgot what it was. Fast forward, someone is interested in acquiring a Flathead and I thought this would be a good candidate. So I pulled a head to check for cracks, not relieved, copper head gaskets, and an industrial engine tag I hardly noticed when I put it in the corner. Also does the casting number account for anything?
RalphM is offline   Reply With Quote
Old 10-13-2021, 05:41 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Interesting 8BA
I've never known the casting numbers on 49-53 blocks to denote anything of value - as all the blocks were basically the same in those years (regardless of car model and destination). Looks like it could be a good rebuild candidate if the block is in good shape.
Old 10-13-2021, 09:46 AM   #3
RalphM
RalphM's Avatar
I have not checked the bore yet, but with factory Ford parts in it, I’m guessing it’s close to standard. I have been squiring MMO in the plug holes over the years I’ve had it. So hopefully it will come apart easily. I also need to look for a date code on the intake surface
Old 10-13-2021, 09:07 PM   #4
flatjack9
flatjack9's Avatar
I've never seen a factory relieved 8BA block.
Old 10-13-2021, 10:43 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
I wonder if that "Industrial Engine" nomenclature might have something to do with that? And even though the tag says Made In U.S.A., I wonder if that "C" as in "C18S" could mean Canada, somehow?
Click Links Below __
T5 W/TORQUE TUBE
Old 10-13-2021, 10:53 PM   #6
tubman
tubman's Avatar
I've never even heard of one.
Old 10-13-2021, 10:56 PM   #7
RalphM
RalphM's Avatar
That’s what I thought.
I cleaned off the carbon in one of the Pistons, and it is indeed standard.
Old 10-13-2021, 11:40 PM   #8
Will D
Will D's Avatar
Here is a link to some Canadian serial number decoding. C18S is on the chart but doesn't correlate with the correct year if I'm reading it right. The write up below explains about lack of details/info for commercial/ industrial serial numbers.
http://wnyrg.org/canvins.html
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
