Old 02-03-2022, 02:25 PM   #1
JOHN CT
JOHN CT's Avatar
Default Oil change surprise !
I changed the oil and when I was cleaning out the drain plug I found a small pice of copper. It looks like a shim stock. I have about 30K on the engine. It runs fine no knocking or tapping. Shall I be alarmed?
Thanks
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 02-03-2022, 02:42 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Oil change surprise !
Thanks
I will admit I don't know what material they are made of, but I don't think shim stock is copper. Not for the mains and rods anyway.
Maybe a picture will help us before people start guessing?
Old 02-03-2022, 02:50 PM   #3
Y-Blockhead
OK, I see. Bratton's has steel or brass shims.
https://www.brattons.com/BRASS-CONNE...ductinfo/8650/
Old 02-03-2022, 08:44 PM   #4
old ugly
old ugly's Avatar
if it were mine i would worry about it, but thats the way i am.
and if it was mine i would pull the pan and have a look.
i would be able to sleep, that thought on my brain.
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 02-03-2022, 08:46 PM   #5
old ugly
old ugly's Avatar
picture of the piece?
old ugly
Old 02-03-2022, 09:30 PM   #6
fordcragar
fordcragar's Avatar
If it were mine, I’d be looking at the bottom end to figure where it came from or what it is. If you don’t, you probably will, only it might cost more than a few gaskets.
fordcragar is offline   Reply With Quote
Old 02-04-2022, 06:36 AM   #7
chap52
chap52's Avatar
Worth dropping the pan for a look see for sure. That's why God gives us winter... Chap
chap52 is online now   Reply With Quote
Old 02-04-2022, 08:11 AM   #8
nkaminar
nkaminar's Avatar
Worth a look. After 30K miles it is time to take up the bearings anyway. This is a maintenance task on an engine that has babbett bearings.
Old 02-04-2022, 10:10 AM   #9
JOHN CT
JOHN CT's Avatar
I don’t have a picture. The pice got tangled up in my shop rags and thrown out I thought of taking when it was to late. Now I have fresh oil in. Before I get involved I’m going to put a few miles on and watch and listen! It’s definitely on my mind
31 Tudor
66 Bonneville
Old 02-04-2022, 11:55 AM   #10
fordcragar
fordcragar's Avatar
By the time you hear anything, it might be too late.
Old 02-04-2022, 12:48 PM   #11
JOHN CT
JOHN CT's Avatar
You know ..your right! I’m going to drop the pan. Hopefully I just have to make some adjustments and don’t get the domino affect. I will feel better once I take a look
Thanks everyone!
31 Tudor
66 Bonneville
Old 02-04-2022, 01:26 PM   #12
Fullraceflathead
Fullraceflathead's Avatar
Is there a chance somebody put 1 of those copper Brillo pads in the oil filter tube maybe just a small fragment in 1 of those if so it's nothing to worry about
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-04-2022, 09:52 PM   #13
Mikeinnj
Mikeinnj's Avatar
Some oil drain plug gaskets are made of copper. Was the piece circular in shape?
Mikeinnj is offline   Reply With Quote
Old 02-05-2022, 10:17 AM   #14
JOHN CT
JOHN CT's Avatar
It didn’t look like a pice of the drain plug. It definitely was outside the edge of a shim. I wish I got a picture of it!
31 Tudor
66 Bonneville
Old 02-05-2022, 11:15 AM   #15
aermotor
I may be wrong, but I thought the shims were brass
aermotor is offline   Reply With Quote
Old 02-05-2022, 12:07 PM   #16
katy
katy's Avatar
Is the engine lubrication system stock? Or modified?
Old 02-05-2022, 02:28 PM   #17
WHN
Please don’t try to fix something that might not be broken.
It was running good before you drained the oil. How is it running now?
If still running and sounding great? Drive and enjoy you car.
People spend a lot of money fixing things that don’t need to be fixed.
Enjoy.
Old 02-05-2022, 02:36 PM   #18
fordcragar
fordcragar's Avatar
I believe in not fixing stuff that isn’t broken, but would at least drop the pan and have a good look. This would be a good time to check the bearings too, and check everything else. Who knows, whoever was in there before might have left something.
Old 02-05-2022, 02:37 PM   #19
Brentwood Bob
Any grandchildren helpers?
Brentwood Bob is offline   Reply With Quote
Old 02-05-2022, 03:53 PM   #20
JOHN CT
JOHN CT's Avatar
Yep …..you read my mind. I have 2 grand sons. It’s going to be a good learning experience after 30k i think it time to take a look anyhow
My A is a great car. For 25 years it’s been turn key and go
31 Tudor
66 Bonneville
