Old 01-29-2020, 01:35 PM   #1
bobH
Default Broke down
Rode home on a burro. The truck was giving some trouble, running bad, then died. From reading this forum, I'm guessing condenser or coil. Maybe fuel pump. I've got some spares, a condenser from JC Whitney, a coil I found at the mine, and a fuel pump from Western Auto. Should be good to go. Going this weekend to fix it and drive it home.
bobH is offline   Reply With Quote
Old 01-29-2020, 01:41 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Broke down
It's worth the effort!
Old 01-29-2020, 01:43 PM   #3
Zeke3
Zeke3's Avatar
Looks like Bonnie and Clyde left it there. I thought the burro broke down. Your plan sounds solid to me, good luck with getting the dwell set correctly.
Zeke3 is offline   Reply With Quote
Old 01-29-2020, 01:47 PM   #4
marko39
The perfect start for your rat rod, might even come with some.
marko39 is offline   Reply With Quote
Old 01-29-2020, 02:12 PM   #5
Jay in Mass
It sounds like you have enough parts to get it running. You might want to bring another battery also because there is a good chance that the battery will be dead also.
Jay in Mass is offline   Reply With Quote
Old 01-29-2020, 03:35 PM   #6
hotcoupe
hotcoupe's Avatar
Pick up a can of dent and scratch remover, it comes in a blue can. Better get the large size!
Tom
hotcoupe is offline   Reply With Quote
Old 01-29-2020, 04:03 PM   #7
4dFord/SC
4dFord/SC's Avatar
Don't forget the Marvel Mystery Oil
4dFord/SC is offline   Reply With Quote
Old 01-29-2020, 04:17 PM   #8
FlatheadTed
FlatheadTed's Avatar
If the pedal goes to the floor you may have a little air in it ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-29-2020, 04:21 PM   #9
Roger W Gerow
When it's running again, consider giving the donkeys a ride home.
DD658
Roger W Gerow is offline   Reply With Quote
Old 01-29-2020, 04:34 PM   #10
marko39
Better bring plenty of beer, looks pretty hot there and a air tank to blow up the tires.
Old 01-29-2020, 04:46 PM   #11
56sedandelivery
56sedandelivery's Avatar
It'll buff right out.
56sedandelivery is offline   Reply With Quote
Old 01-29-2020, 04:56 PM   #12
mfirth
Nice patina....also well ventilated.....
mfirth is offline   Reply With Quote
Old 01-29-2020, 05:08 PM   #13
RalphM
RalphM's Avatar
Eastwood sells “patina preserver” for that!
It’s all the rage to leave it as found.
Watch out for snakes!
RalphM is offline   Reply With Quote
Old 01-29-2020, 05:09 PM   #14
cmbrucew
cmbrucew's Avatar
Straighten the grill and get some stainless trim items and she's good to go.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 01-29-2020, 05:29 PM   #15
Fordestes
Looks like it was used too much when it was new .
Fordestes is offline   Reply With Quote
Old 01-29-2020, 09:44 PM   #16
Tinker
Tinker's Avatar
Ran when parked. Came with a standard 2 burro ford engine. Just needs tlc.
Old 01-29-2020, 09:48 PM   #17
Talkwrench
Talkwrench's Avatar
SO you got air -con....?
Old 01-29-2020, 10:20 PM   #18
alanwoodieman
the mugruder valve has to be stuck, take along a BFH, we sailors could fix anything with that!!
Old 01-29-2020, 11:14 PM   #19
al's28/33
al's28/33's Avatar
right front tire looks low to me, keep her under 55.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 01-30-2020, 12:28 AM   #20
JM 35 Sedan
JM 35 Sedan's Avatar
I'd say you found yourself a real jewel right there. Enjoy!!
John
