Old 09-21-2016, 08:40 PM   #1
1930-fordor
1930-fordor's Avatar
Default what kind of drum is it
These drums were on the car when I became it's new care giver.
could someone give me any info on what they are. I can't find any info.
1930-fordor is offline   Reply With Quote
Old 09-21-2016, 08:44 PM   #2
Mitch//pa
Default Re: what kind of drum is it
http://fordbarn.com/forum/showthread...+Mountain+drum
Old 09-21-2016, 08:59 PM   #3
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
I have 2 of those drums that I've listed for sale.
I do not have a micrometer.
Originally they were 11 inches. These measure 11 and 1/16 inch.
Does anyone know how far over they probably are. Do you think they may have been turned too far?
Thanks, Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 09-21-2016, 09:07 PM   #4
1930-fordor
Thanks Mitch, If I understand correctly, this old style of casting drums will wear out more quickly and become unsafe at that point???? are they safe up until that point? or should they be replaced sooner?
Old 09-21-2016, 09:14 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
11 1/16 would be turned .0625", and I'd run them with no problem.
Old 09-22-2016, 11:52 AM   #6
Big hammer
Would there be a problem with the shoes,springs,linkage open to the weather, road debris?
Old 09-22-2016, 11:58 AM   #7
1931 flamingo
1931 flamingo's Avatar
Your wheels will cover the exposed area. No problem, they were standard issue by Ford late 31.
Paul in CT
Old 09-22-2016, 02:02 PM   #8
Big hammer
Ok I see now in the pictures, I was thinking of them as cooling holes. My late 31 doesn't have them Nov 1931. Maybe I should put them on my ever growing list :-) So the holes are for rotational weight saving?
Old 09-22-2016, 02:20 PM   #9
daveymc29
daveymc29's Avatar
I have 12 inch on my coupe. they really stop the car. I understand they are 1932's. I have had no problem with them, even in the rain. Just came that way when I bought the car. guess a prior owner wanted to have the fronts do most of the braking, not a bad plan, I have heard. 11 inch stock on the back. I'd love to find a pair for the front that were turnable.
daveymc29 is offline   Reply With Quote
