03-23-2018, 08:30 AM | #1 |
Tappet noise
Has anyone ran a B engine with the side cover off? my concern is the oil mess. Thx. Daren
03-23-2018, 08:49 AM | #2 |
Re: Tappet noise
Please ignore the previous message. I just realized there would be a lubrication problem. Daren
03-23-2018, 10:28 AM | #3 |
Re: Tappet noise
noise...I use a mechanics stethoscope to isolate odd noises
03-23-2018, 05:34 PM | #4 |
Re: Tappet noise
Stethoscope does not work. I have a noise that sounds like a lifter. I have adjusted the clearance's now three times per the procedure. They are all within specs. The noise is really loud when cold but almost goes away when warmed up...Almost.
03-23-2018, 06:59 PM | #5 |
Re: Tappet noise
How many miles on engine. What weight oil are you using.
I’m old school. If not new rebuild, I would add MMO to gas, STP to oil. Model A engines can make different noises, doesn’t mean there is a problem. The older I get, the more of the same problems. Enjoy. |
03-23-2018, 07:27 PM | #6 |
Re: Tappet noise
03-23-2018, 07:44 PM | #7 |
Re: Tappet noise
Do not run a B without the side cover...Ever.
03-25-2018, 01:40 PM | #8 |
Re: Tappet noise
You could with a plexiglass cover like Ken dit with an A engine, to insure oil still gets to the bearings.
03-25-2018, 01:49 PM | #9 |
Re: Tappet noise
Could be the cam gear coming apart. Take the side cover off and check it out. Or the spring that put tension on the cam is bad.
