01-12-2019, 02:17 PM | #1 |
Burnt Out Headlight
What would cause a headlight to burn out quickly?
I installed a new headlight and it burnt out the first time I turned the lights on. The other light works fine.
John from Kapowsin T&A Guy |
01-12-2019, 02:50 PM | #2 |
Re: Burnt Out Headlight
A bad or loose ground can do it, or a bad bulb.
01-12-2019, 02:57 PM | #3 |
Six volt bulb, 12 volt system (maybe mislabeled from manufacturer)? Cheap bulb/poor quality control? Bulb dropped damaging filament? If the car was running maybe voltage spike from generator?
Charlie Stephens |
01-12-2019, 03:38 PM | #4 |
Manufacturing defect. It happens.
Enjoy yer day. Tom Hate can't fix what it started. |
01-12-2019, 04:39 PM | #5 |
i have a stash of sealed beam bulbs here saved from junkers, 6&12v, and once in a while when testing the bulb will light, then fill with smoke, then dead. it happens instantly, makes you angry, and i have never know why it happens. bad ground is my guess. usually testing done with a small battery charger. any thoughts?
01-12-2019, 06:28 PM | #6 |
01-12-2019, 07:21 PM | #7 |
by golly that makes sense mr a bones ! i guess i saved em too long. shoulda been used before they leaked
01-12-2019, 08:18 PM | #8 |
I've been overdue for a score.
