06-02-2015, 10:51 AM | #1 |
First for me
While driving back to my house in my 30 Model A coupe, I heard a very loud Ka Boom followed by the car jerking to the left. Sounded like a shot gun going off. I pulled over to see WTF is going on. Nothing visible so I shook the front fire and was amazed at what I found. The outer wheel bearing literally flew apart. The inner race had gotten so hot it welded itself to the spindle. Complete bearing failure. Now what caused this? Both bearing had plenty of grease and it was not over tighten. Strange....
06-02-2015, 11:41 AM | #2 |
Re: First for me
Kinda sounds as if the bearings were bad when greased or the bearing was defective from the start. Maybe the cotter had been left off.
06-02-2015, 12:01 PM | #3 |
Re: First for me
I've seen that happen, but only if the bearing was dry or tightened too much.
I've seen the outer part of the hub shatter from the bearing being tightened too much. |
06-02-2015, 02:36 PM | #4 |
Re: First for me
Grease packed tapered roller bearings like the Model A front wheel bearings must not have preload! They need some end play, like .001-.005". If you tighten the nut past zero end play, thus preloading the bearings, you squeeze all the grease off the rollers and races. The bearing is now running dry, gets hot, seizes, the inner race starts spinning on the spindle, welding itself solid to the spindle! With a slight amount of end play, a film of grease stays on the rollers and races and the bearing lives a long and happy life-maybe 86-87 years and counting! (If cleaned and repacked regularly) No matter how much grease one stuffs into the hub, the bearings are only lubed by that initial film of grease on the rollers and races.
A tapered roller bearing in a differential, on the other hand, is under preload to hold gears in precise alignment, but here the bearing is lubed and cooled by a constant bath of gear oil. |
06-02-2015, 02:49 PM | #5 |
Re: First for me
wow! that's some scary stuff
06-02-2015, 03:03 PM | #6 | |
Re: First for me
06-02-2015, 03:17 PM | #7 |
Re: First for me
That is how I was taught. Others disagree. I snug the castellated nut, then back off one slot, spin the tire, check the vertical movement for obvious looseness, then install the cotter pin that is a tight fit in the hole, and run it.
Bob |
06-02-2015, 03:40 PM | #8 |
Re: First for me
Mitch, they're not. Every late model Ford service manual I've looked in says something like: 'tighten adjusting nut to 25 ft. lbs. (or similar figure), rotate hub several turns in each direction to seat bearings, then back off nut until completely loose and readjust to achieve .000-.005" endplay'. Other manufacturers have similar instructions that give the same results. I spent the last 27+ years as a mechanic for the Arizona Hiway Dept. More than once a vehicle would come in with a destroyed front wheel bearing (usually the outer) and the driver would say "It was just in such-and-such shop" so I would check history on the computer and find it just had brakes or its yearly service and see new wheel seals on the work order. So I would check the bearings in the other side and find them adjusted way too tight (significant preload) and see signs of imminent failure (totally dry bearings and discoloration although the hubs were full of bright red Mystik grease.
06-02-2015, 03:48 PM | #9 |
Re: First for me
I'm not one for putting much if any preload on and I am also not one for leaving it go with any end play either. I like 0 no end play or a hair more 0+,, 0+ 3/4. After driving it's possible they can loosen to a very small amount of endplay, I would then remove the play. If that was to happen...
Here is the spec for the mustang with the same style bearings. Last edited by Mitch//pa; 06-02-2015 at 03:57 PM. |
06-02-2015, 05:02 PM | #10 |
Re: First for me
You can read & hear ANYTHING, or be TAUGHT" by ANYBODY, but did the "teacher"?? know what the F**K he wuz talkin' about????
Some outer wheel bearing failure is caused when someone re-adjusts a loose bearing & doesn't AT LEAST pop out the outer bearing & pack it!!! The inner will usually have enough grease to go awhile longer. I DON'T jist BABBLE, I've had a DAMN lot of EXPERIENCE & if that sounds like bragging, WELL---------------------------------------------------- Bill W.
06-02-2015, 05:09 PM | #11 |
Re: First for me
An important note in the picture Mitch just posted is step #3 says 10-12 inch pounds, and not foot pounds.
10-12 in. lbs. is equal to 1 foot pound or a hair less. |
06-02-2015, 05:14 PM | #12 |
Re: First for me
06-02-2015, 05:41 PM | #13 |
Re: First for me
But not loose and no endplay
06-02-2015, 06:10 PM | #14 |
Re: First for me
Is that a RCH or less?
The Master Cylinder Enjoying life at the beach in SoCal... |
06-02-2015, 06:12 PM | #15 |
Re: First for me
06-02-2015, 08:27 PM | #16 |
Re: First for me
The Master is not BAD, Mitch, just EXPERIENCED! By the way, it's speled RKH, not RCH!!
Bill W.
06-02-2015, 08:49 PM | #17 |
Re: First for me
I prefer blond, so do I use the same torque spec?
06-02-2015, 09:26 PM | #18 |
Re: First for me
Depends if its bleached or natural......
Alive n kickin n mostly kickin! |
06-02-2015, 09:45 PM | #19 | |
Re: First for me
then mount tire on it and really let it whirl and see what its doing.
1929 Model AA - Need long splash aprons! |
06-03-2015, 12:46 PM | #20 |
Re: First for me
Bill, I want my zip it rack back now.
Bob |
06-03-2015, 01:58 PM | #21 |
Re: First for me
WHY???????????????????????????????????????:ee k::ee k::confuse d::confuse d:
Bill W.
06-04-2015, 09:34 AM | #22 |
Re: First for me
Bill, sent you a pm. Hope that explains it. I think the comments above helped make others aware of the need to take care with the proper adjustment of the tapered bearings. Apologise for the comment in #20. Please ignore it. I had a bad day. Bob
