06-26-2019, 10:52 AM | #41 | |
Re: 64 Galaxie w/manual steering hard to turn
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-01-2019, 01:23 AM | #42 |
I have replaced everything but the Concentric lower arm bolts. It was suggested to check tire pressure, it was ok , I added couple more #'s which helped a little. Someone suggested swapping the front wheels. BINGO that did IT NOW STEERS MUCH EASIER!! I mean big difference.
Our best local shop that still has the old style alignment equipment cannot keep the front end aligned properly because of the concentric lower arm bolts. I plan to replace the bolts using the Born Again Classic Offset Shaft Conversion kit. Last edited by callbald; 07-01-2019 at 06:21 PM. |
07-02-2019, 04:51 PM | #43 |
Ok one step further on the hard turning issue. Found one of the replaced tires had a radial belt issue.
