08-16-2018, 06:39 PM | #1 |
3 spd OD parts ?
I got my transmission at the shop, second gear issues hard time getting it in second and it’s popping out. Shop is looking for parts having a hard time. Says he needs shift collar,second gear,gasket set & synchro. Where is a good place to get parts ? Vanpelt ? TIA
08-16-2018, 06:42 PM | #2 |
Re: 3 spd OD parts ?
Mac [VP] will have the parts , or James at Gotham city Auto parts. Should be plenty of stuff around.
"Came too close to dying to stop living now!" |
08-16-2018, 08:05 PM | #3 |
What is Mac [vp] ? Thanks
08-16-2018, 08:18 PM | #4 |
Mac van Pelt.Google will show contact if someone doesn't post.
08-16-2018, 08:23 PM | #5 |
08-16-2018, 08:24 PM | #6 |
08-16-2018, 08:24 PM | #7 |
Ok thanks. I didn’t get the abbreviation. I gave the shop his number.
08-17-2018, 09:24 AM | #8 |
These transmissions are a lot like the earlier Ford side & top shift transmissions except for the overdrive system. Intermediate gear or 2nd is the rear side of the two synchronized speed selections with the high 1 to 1 drive or 3rd being in the front. The 2nd gear pop out is usually a thrust surface wear indication. Clearances have to be to minimums to reduce the possibility of the 2nd gear synchro being forced out of mesh. I hope you rebuilder checks all the thrust surfaces well.
Tell your rebuilder than Mac VP has shaft snap rings that are much easier to remove and intall then OEM and they are the correct thickness to maintain correct internal clearances. He has a thrust washer kit for the cluster gear that a person can get proper clearances with. He makes an effort to get the best parts that are currently available. His transmission book for the old Ford units is the best reference I've yet found. It doesn't cover the overdrive but it's good for the gearbox. |
08-17-2018, 10:33 AM | #9 |
To further what Rotorwrench has said, there is a lot of good info on the internet re the R-10 & R-11 Borg Warner Overdrive systems.
08-19-2018, 12:49 PM | #10 |
OK thanks.rotorwrnch I will call him on Monday.
08-19-2018, 06:37 PM | #11 |
Mac has a book, (booklet) on the overdrive transmissions as well as the main book.
