Old 11-14-2020, 12:05 PM   #1
flathead 39
flathead 39's Avatar
Default New Gauges for 39 Deluxe
Has anyone installed New Vintage USA Woodward Series gauges?
flathead 39 is offline   Reply With Quote
Old 11-22-2020, 03:03 AM   #2
fortyonerag
fortyonerag's Avatar
Default Re: New Gauges for 39 Deluxe
Probably not much help to you, but I just installed NVU Oil Press and Temp accessory gauges in my 41. I had an issue with the temp sensor and NVU have agreed to send me a new one to Australia - no hassles.
I was pretty pleased with their attitude.
fortyonerag is offline   Reply With Quote
Old 11-22-2020, 05:09 AM   #3
Zeke5180
I'm currently installing the Woodward Series in my 37. Almost identical to yours. Maybe I can help.
Zeke
Zeke5180 is offline   Reply With Quote
Old 11-22-2020, 11:47 AM   #4
flathead 39
Zeke
Thanks, I'd sure like to know if you have any problems. I'll be doing this in a couple weeks.
Jim
Old 11-22-2020, 10:46 PM   #5
Zeke5180
Jim,
One problem I did come across was the fuel gauge. Always read full. I was able to determine the fuel sending unit I had in the tank would only work with the original Ford gauge. When I first purchased the car several years ago I had to replace the fuel tank, the sending unit and an electric fuel pump. All were trashed from sitting for a number of years. At that time the car was still 6v positive but the sending unit was good for 6 or 12 volts. Also make sure your grounds are good.
This is a first time for me so I'm no electrical wizard but if I can help any further let me know.
Zeke
Old 11-23-2020, 11:48 AM   #6
flathead 39
Zeke,
Thanks for that, the only original gauge that works is my fuel gauge! I expect to receive the set around the first of Dec.
Jim
Old 11-23-2020, 11:52 AM   #7
40cpe
40cpe's Avatar
do those gauges fit the factory holes in the '37-'39 dash?
Old 11-23-2020, 07:24 PM   #8
Zeke5180
40 Coupe,
They did for the 37, I believe they're 4 3/8" .
Zeke
Old 11-25-2020, 07:16 PM   #9
40cpe
40cpe's Avatar
Thanks
Old 11-26-2020, 04:48 PM   #10
Ggmac
All senders will have to be replaced including fuel . Change to 12 volts and possibly your original distributor . I say dist only if the odometer is of the gps style , the noise from generator and maybe the dist will interfere. I installed a set for a friend , and now going back through it , we did have a 12 v generator that was probably the noise interfering with the gps antenna/ signal .
Ggmac is online now   Reply With Quote
Old 11-30-2020, 07:14 PM   #11
flathead 39
Zeke5180
What kind of speed sender are you using?
Jim
Old 12-04-2020, 03:24 PM   #12
flathead 39
It's crazy, but the sender that fits my 39 transmission is the one that is for GM products, 99001-04, and the one listed for Ford products, 99006-04 won't fit the 39 ford. This according to NVU cust svc.?!
Old 12-04-2020, 04:31 PM   #13
JayChicago
JayChicago's Avatar
The one for Ford products is probably for modern Ford products. I would trust the NVU techs. I dealt with them to troubleshoot a problem with the Woodward set that came in my '37. Turned out they were right, I was wrong.
Old 12-04-2020, 09:29 PM   #14
flathead 39
As it turns out, that's the case, but when I first contacted them they gave me the number for the ford sender. In looking at the picture, I couldn't see how it could connect with my trans. So I sent them a picture of the speedo drive gear assy and asked how to connect the ford sender. That's when they replied that I needed the GM sender. So I have that one on order now..
Old 12-05-2020, 06:15 PM   #15
Zeke5180
Flathead 39,
Sorry for the late reply. I'm using the the Ford unit, 99006-04. In my case I unscrewed the unit and basically used the front half which screwed directly in my stock 37 trans. If I can figure out how to post a photo, I'll show you the part I removed.
Zeke
Old 12-05-2020, 08:23 PM   #16
flathead 39
Thanks Zeke, looks like either one will work. I'll know more when I get the GM 99001-04.
Old 12-29-2020, 11:58 PM   #17
flathead 39
Installation complete. All gauges working. I think I may have a linear vs non-linear problem in the gas gauge/sender but it's working. btw, the gas tank sender is the only one I didn't replace.
Old 12-30-2020, 09:42 AM   #18
JayChicago
JayChicago's Avatar
Looks great!
Old 12-30-2020, 10:53 AM   #19
Zeke3
Zeke3's Avatar
Very nice looking gauges.
Zeke3 is offline   Reply With Quote
Old 12-30-2020, 11:31 AM   #20
flathead 39
Thanks guys, I'll never argue that they are as good looking as the original. However I needed to git rid of the under dash gauges and replace them with not bad looking gauges that are reliable. Not to mention the extras you get with electronics. Here's the before shot. I'm satisfied with the results.
