Old 07-13-2019, 11:45 AM   #1
russcc
Default '40 front pass brake line, (pipe)
The prior caretakers of the '40 replaced the right front brake line. Kind of a sloppy job. I have bent up a replacement, and would like to see how Ford originally bent the end of the line & fitting to attach to the right front passenger side brake hose in the bracket on the frame. Anyone have a photo they could share. Thank you Fordbarners.
russcc is offline   Reply With Quote
Old 07-13-2019, 12:25 PM   #2
Kube
Kube's Avatar
Default Re: '40 front pass brake line, (pipe)
Here ya go...
Old 07-14-2019, 06:26 AM   #3
russcc
Thank you Mike
Old 07-14-2019, 06:30 AM   #4
russcc
Anyone sell these either NOS, NORS, or current pre-made. I can make my own, but it would be quicker to get one already made.
Old 07-14-2019, 03:22 PM   #5
supereal
supereal's Avatar
C&G (800) 266-0470) sells brake line kits with the lines at correct pre cut lengths, including the necessary nuts. For your 40 order 91A-2269, $58.50. Use your existing lines to bend the replacements into shape. If you plan to make your own lines be aware that you need a special tool to form the double ends of the lines. If any of the current lines on your car show evidence of tampering, it is best to replace all lines, including the three hoses. The drum brakes on old cars are already at a disadvantage to modern vehicles with disc brakes and dual systems. At our shop, we regularly find rusty lines, mostly due to winter driving, some repaired with compression fittings, or even copper tubing! These are really accidents waiting to happen!
supereal is offline   Reply With Quote
Old 07-15-2019, 08:58 AM   #6
TJ
TJ's Avatar
Bob, it's amazing what some people will do to avoid doing it right. Even to their own detriment.
Old 07-15-2019, 01:43 PM   #7
hotcoupe
hotcoupe's Avatar
I sent an original to "Inline Tube"for them to copy. So they should have that info in a ditial file, i'm sure they would be happy to make one for you.
Tom
hotcoupe is offline   Reply With Quote
