10-13-2016, 11:55 AM | #1 |
elongated holes for steering box on a 34 frame
I just rebuilt the steering box on my 34 coupe and noticed that the three holes in the frame that it bolts to were elongated. Is this factory or has someone done it to lower the steering column? I was going to weld them up but thought I should ask first after reading that some 32's came with elongated holes. What about 34's? Thanks, Steve
10-13-2016, 01:49 PM | #2 |
Re: elongated holes for steering box on a 34 frame
My guess is that they came that way. Being elongated allows for proper alignment of the steering box and shaft . I always loosely bolt the box to the frame and then tighten the column drop to the dash. If you bolt the box tight first you run the risk of the shaft being in a bind when the column drop is mounted.
10-13-2016, 01:51 PM | #3 |
Yes they came that way Ted
10-13-2016, 02:12 PM | #4 |
Same as '32...same frame was used on pickups and passenger. The shorter cowl on the pickups meant the steering angle was different...slots allowed use of same box tilted to suit.
10-13-2016, 02:19 PM | #5 |
Related question. Can the steering box be slightly lowered to accommodate a header which just kisses the box, thus preventing installation of the header? I'd rather not dimple the header tube to accommodate the box.
Jack E/NJ |
10-13-2016, 02:55 PM | #6 |
10-13-2016, 04:47 PM | #7 |
34s had the elongated holes ,at least Canadian or foreign RH drive .Ted
10-13-2016, 05:10 PM | #8 |
My comment about round holes was limited to '32s.
10-13-2016, 05:19 PM | #9 |
OK. So can I accommodate a header that's kissing an early 38 steering box by lowering the box instead of dimpling the header? Thanks.
Jack E/NJ |
10-13-2016, 05:47 PM | #10 |
Jack:
Yes you can. You can do what ever you want. Whether it is a good idea is a different question. Personally I would not modify or alter Ford parts but would modify the non ford part - namely the header. Could you create a clearance by spacing the engine mount just a tad? Mart. |
10-13-2016, 07:36 PM | #11 |
Thanks for the help! After reading the replies I looked at the passenger side and it was set up for RHD with the same elongated holes. Steve
10-13-2016, 08:15 PM | #12 |
Mart>>>Could you create a clearance by spacing the engine mount just a tad? >>>
Guess I could, Mart. Seems like there's a bit of slop in both the engine and tranny mount holes. Maybe also loosen the nuts on the tranny mount. Easy to do now since the floor is out. Then nudge the whole affair a quarter inch or so toward the passenger side. The universal joint probably wouldn't notice. Whaddya think? Or should I just pound a dimple in the header to be on the safe side? Jack E/NJ |
10-13-2016, 09:52 PM | #13 |
would not the elongated holes be there to allow the steering box to be adjusted in the car,as when the adjustments are done the the part that bolts to the chassis moves in relation to the box.
lawrie |
10-14-2016, 02:26 AM | #14 |
Don't move the trans mount to the side, (assuming torque tube drive) as it will "steer" the rear axle off line a bit.
10-14-2016, 08:43 AM | #15 |
Mart>>>Don't move the trans mount to the side, (assuming torque tube drive) as it will "steer" the rear axle off line a bit.>>>
Mart---Then I guess I don't see how it'd be possible to space the engine mount just a tad without also affecting the solidly-connected transmission alignment? For that matter, the anti-chatter rods probably wouldn't allow it anyway. So at this point I guess my only options are to dimple the tube with a hammer or determine if the box can be 'easily' lowered a tad. Jack E/NJ |
10-14-2016, 09:22 AM | #16 |
Saw a video done by Hot Rod magazine where they dynode an engine, then proceeded to bash in header tubes with a blacksmith hammer. Power output was not affected until tubes were crushed nearly flat. So a dimple or two won't hurt anything.
10-14-2016, 09:33 AM | #17 |
Yeah, I saw that video and result too. But, as Lawrie suggested, if the elongated holes are there, an adjustment downward is probably possible. I don't need more than a 1/4" of clearance to avoid having to bash the header.
Jack E/NJ |
