09-29-2013, 11:33 AM | #1 |
screwed up my wiring
I put a new harness in the car and just noticed that my taillight is always on. Whether the switch is on or not. If I rotate the headlight switch the license plate light goes on or off the way is should. What did I do?
Short URL: http://smu.gs/14g7eDW |
09-29-2013, 11:51 AM | #2 |
Re: screwed up my wiring
You sure it's not the stop light that's on?
Bob |
09-29-2013, 12:05 PM | #3 |
It's got to be the stop light. You mention that the license plate light goes on and off per the switch. That bulb is the tail light (the upper of the two bulbs) so the tail light IS working. Is the stop light switch bound up?
Don't never get rid of nuthin! |
10-01-2013, 07:22 AM | #4 |
Crap! the stoplight switch moves freely. Something must be grounding it out. That said, does the stoplight work even when the car is switched off?
10-01-2013, 07:26 AM | #5 |
Yes, Ot wiil work even when the car is off. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
10-01-2013, 07:57 AM | #6 |
10-04-2013, 07:33 PM | #7 | |
Also, is the spring between the pedal and switch going slack when the pedal is up?
