02-25-2020, 10:17 AM | #1 |
I am ignorant and proud of it!
OK..I just can't connect my grounded battery cable to the positive post of my battery. Physically I can, but not mentally. So, I need to make my 55 F100 6 volt a negative ground system. I don't have a radio or heater. I have a light for the gen and oil. I know I need to change the leads on the coil, and probably polarize the gen/reg. Is there anything else I need to change, to make this work? Any gauges, how about the horn? Thanks for any and all help.
02-25-2020, 11:04 AM | #2 |
Re: I am ignorant and proud of it!
Since you have an idiot light instead of an ammeter you're good to go with what you listed. If you had an ammeter you'd need to reverse the direction the wire for it goes though the loop on the back so it won't indicate backward.
Often wrong but never in doubt. |
02-25-2020, 11:48 AM | #3 |
Idiot light..Hmmmm. Thanks for the info...
02-25-2020, 12:04 PM | #4 |
Yes check the leads on the coil. The Red w/ Green stripe wire from the "C" terminal of the ignition switch should attach to the "+" or "Ign" terminal of the coil, and the "-" or "Dist" terminal will connect to the points in the distributor.
A working 6v heater fan would not need any wiring changes. The gauges, horn and horn relay should not be affected if they were working well before. IF the truck had an oem clock the polarity tab on the back would need to change. to Polarize the Generator * When the wiring job is done, before you start the engine, remove the Field wire from the voltage regulator and very briefly touch it to the Battery terminal of the voltage regulator (you will get a small spark) then reconnect the Field wire to it’s position on the voltage regulator. * . Last edited by dmsfrr; 02-25-2020 at 12:11 PM. |
02-25-2020, 12:38 PM | #5 | |
02-25-2020, 03:13 PM | #6 |
02-25-2020, 04:26 PM | #7 | |
If it hasn't been mentioned before, they need to be large "0" or "1" gauge cables, not the cheaper generic 4 or 6 gauge cables from the corner parts store used in newer 12v cars. (photo) The smaller ones can't deliver the power needed to turn the engine on 6 volts. . Last edited by dmsfrr; 02-26-2020 at 12:57 PM. |
02-26-2020, 11:44 AM | #8 | |
02-26-2020, 12:29 PM | #9 |
02-26-2020, 11:27 PM | #10 |
It's been way to many years, but, Ford was not the only car to run positive ground. There was also I believe, a couple of positive ground 12 volt cars also. Very difficult for a young kid to remember. My boss helped out by telling me the different sizes of the terminals. They don't fit when reversed.
02-27-2020, 08:04 AM | #11 | |
02-27-2020, 09:48 AM | #12 |
try hypnosis
02-27-2020, 11:50 AM | #13 | |
"Electron Flow is what actually happens and electrons flow out of the negative terminal, through the circuit and into the positive terminal of the source." So you see, connecting the positive cable to ground does make sense! Here's another quote from the same source: "In fact, it makes no difference which way current is flowing as long as it is used consistently. The direction of current flow does not affect what the current does." Of course, some electrical devices are polarity sensitive, so this has to be taken into account (which Ford and the others did when they designed their positive ground systems). So I say don't mess with success! Hope this helps! |
02-27-2020, 09:41 PM | #14 |
02-27-2020, 09:49 PM | #15 | |
02-27-2020, 10:59 PM | #16 | |
Depending on the vehicle model there are other ground wire connections between the: battery & body, engine & body, engine & frame, some body panels, etc. They may have been flat braided or large-ish gauge round twisted wires. Some were insulated others were not. They most often had round or lug terminals at the ends because they were fastened on with bolts or screws and didn't connect to other circuits. This 'as found' example firewall to engine block ground wire may have originally been insulated. Small bits of crunchy plastic remained and the copper wire is noticeably discolored and feels brittle, likely from being seriously overheated. Possibly due to: a very bad short, its small diameter and/or jump starting a stubborn car with the Ground jumper cable connected to the body instead of the Ground battery cable. (nearly all the starter power would have tried to go thru it, compare to the previous photo of "0" gauge starter/battery cable size wire) Last edited by dmsfrr; 02-28-2020 at 12:47 AM. |
02-28-2020, 01:03 AM | #17 | |
Both positive ground and negative ground systems are wired the same. There is a 'hot ' wire carrying current from the battery to each device (or it's switch) and a 'ground' wire going back to the battery to complete the circuit. Most often the device (radio, heater motor, lights, etc.) is grounded to the frame or body, then a ground strap (or cable) runs from the firewall, frame, or engine to the battery to complete the circuit. It may help to ignore polarity while you're doing the rewire. Just think "hot" and "ground". Label the cable that goes from the battery to the starter solenoid as "Hot" and the cable that goes from the battery to the firewall, etc. as "Ground". Tape up the ends of the cables so you can't tell which is "positive" and which is "negative". Then do your repairs as you see fit. If it helps to pretend you have a negative ground system, that's fine. It makes no difference to how the repairs are done. Find a factory wiring diagram and follow it if needed. When you're done and ready to test, untape the cables and connect the one you labeled "Hot" to the negative battery post. Remember, current flows out from the negative battery post to the lights, horn, etc. then back to the positive battery post anyway, so a positive ground system is not really "backwards". |
02-28-2020, 08:47 AM | #18 | ||
02-28-2020, 11:04 AM | #19 |
The original wiring insulation is rubber with a cloth covering that is nearing 70 years old. The cloth covering disintegrates over time and the rubber cracks. Messing with it just makes matters worse because fixing one spot puts a strain on other spots so that you will be constantly chasing bare spots and possible shorts due to the conductors touching bare metal or each other. It's a fire waiting to happen. Best to bite the bullet and rewire the car with modern harnesses. JMO
02-28-2020, 11:45 AM | #20 | |
02-28-2020, 12:25 PM | #21 | ||
The big cable from the Solenoid down to the Starter is on the "Hot" side of the circuit, the bare metal parts of the car are the "Ground" side of the circuit. If the starter wire has bare spots it needs to be replaced / repaired asap. The same with any other crumbling wiring insulation. Quote:
The only practical reason to not change would be if you want to keep an original radio (or other accessory) and it had to stay positive ground. If Positive = Hot and Negative = Ground just makes more sense in your head, make it easy on yourself and change them to negative ground. Late night repairs in the shop will cause less headaches and unscheduled jump-starts will create fewer sparks. PS: keep a pair of fire extinguishers on the floor in the back seat until (and even after) you replace the wiring. Also remembering that any rubber fuel line parts that haven't already been replaced are in similar condition to the crumbling insulation on the wiring. Last edited by dmsfrr; 02-28-2020 at 12:42 PM. |
02-29-2020, 12:36 PM | #22 | |
02-29-2020, 02:51 PM | #23 |
tommyleea...Quite the interesting title for a thread! Coincidentally, check-out my signature line in maroon. So, who wins...you, or me? Does a thread title trump a signature line, or vice versa? DD
03-01-2020, 08:42 AM | #24 |
Actually, you win, because that is where I got the idea! I was waiting for you to jump in.
03-01-2020, 08:31 PM | #25 | |
Ha....You got me laughin' my butt off. If you weren't so damned far away it might be fun to sit down and drink a beer with ya. DD |
03-01-2020, 10:21 PM | #26 |
