Old 02-01-2020, 07:14 PM   #1
Vanspeed
Vanspeed's Avatar
Default 2 bolt crab on a 21 stud question
Hi guys. I ordered a rebuilt 2 bolt crab distributor from Bubba. I have a 3 bolt cover and a 2 bolt cover. Can I just bolt the 2 bolt cover on and be good? My cam has a fiber pressed on gear. Just want to know what all I need to make the swap.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 02-01-2020, 07:24 PM   #2
Kube
Kube's Avatar
Default Re: 2 bolt crab on a 21 stud question
Nope, you can't just bolt it on. The distributor housing is "deeper" on the crab than on the authentic helmet style and as such the crab must be spaced outward to accommodate this.
Old 02-01-2020, 07:36 PM   #3
cas3
speedway has the spacer. most, mine and others i have heard of, require a little trimming around the vacuum port. not a big deal, a few swipes with a file. i cant remember, but i think it hits a timing cover bolt or something. check the fit when you get it.
Old 02-01-2020, 08:51 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Here's the 2-bolt spacer at Speedway. Click the link below! DD
https://www.speedwaymotors.com/Flath...cer,25074.html
Click Links Below __
T5 W/TORQUE TUBE
Old 02-01-2020, 09:00 PM   #5
Vanspeed
Vanspeed's Avatar
Ok cool that is not a bad price at all to make it all work.
Old 02-01-2020, 11:59 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
You also have the option to stay with the original, to that 21 stud engine, three bolt cam gear cover, and go with the spacer that bolts to the three bolt cover, and accepts a two bolt distributor. When going this way you could initially go with the two bolt crab style distributor, but quickly change back to a three bolt style distributor if you ever wanted to go back to your original distributor. This is the option I prefer to use on my '35, 21 stud engine so I can run my two bolt Harmon Collins distributor with the 3 to 2 bolt adapter, or quickly switch back to the stock 3 bolt distributor, if/when I ever care to do so, without the need to change the timing gear cover. Its mostly about flexibility for me on long distance touring.
Here's a picture of the late, great Dick Spadaro's reproduction offering of a three bolt to two bolt adapter for mounting a crab style two bolt distributor on an original three bolt timing gear cover used from '32 to '41.
John
Old 02-02-2020, 10:34 AM   #7
Mart
Mart's Avatar
I run a crab distributor on a 3 to 2 bolt adaptor on the 21 stud Pilot motor in my 33 coupe.
Old 02-02-2020, 09:40 PM   #8
Tinker
Tinker's Avatar
https://www.jalopyjournal.com/forum/...dapter.217554/
Old 02-13-2020, 09:24 AM   #9
Ol' Ron
Ol' Ron's Avatar
You can also run a late style 49/53 dist with a gear drive adapter and the late front cover. However your cam protrudes out from the cam and the adapter must be clearanced or the cam ground down.. Not an easy project. and the crab distributor is a good one.
Old 02-25-2020, 06:49 PM   #10
Vanspeed
Vanspeed's Avatar
Hey guys if I am going for optimal clearance, meaning distributor as close to the cover which one do I use? I have both a 3 and 2 bolt cover. I think the 2 bolt cover and spacer will get me closer to the engine. Reason I ask is because I am running a ‘46 crank gear, fan with hub and generator. I don’t want the crab pushed out to far to interfere with the fan belt.
Old 02-25-2020, 07:12 PM   #11
Mart
Mart's Avatar
Vanspeed: What cam do you have in it? If the 46 type cam then the 2 bolt cover and the crab dist. will bolt right on. No spacer required.
Old 02-25-2020, 07:20 PM   #12
JM 35 Sedan
So you're running a '46 front crankshaft gear on....which year crank shaft?? So...which cam and camshaft timing gear are you actually using in your 21 stud engine?? There are what's known as long and short cams, and depending on which one you have, will determine if you need a distributor spacer or not. Your first post says... press on fibre timing gear, which usually/normally means you have the long style camshaft, but let's make sure before we attempt to answer your last posted question....
John
Old 02-25-2020, 07:20 PM   #13
Vanspeed
Vanspeed's Avatar
Just looked and it is the press on type fiber cam gear.
Old 02-25-2020, 07:23 PM   #14
Vanspeed
Vanspeed's Avatar
Yeah I know you are thinking why a ‘46 crank pulley and fan? I am fitting a 36 LB engine into my ‘29 A coupe and I needed a mechanical fan that was in the center of my radiator.
Originally Posted by JM 35 Sedan View Post
So you're running a '46 front crankshaft gear on....which year crank shaft?? So...which cam and camshaft timing gear are you actually using in your 21 stud engine?? There are what's known as long and short cams, and depending on which one you have, will determine if you need a distributor spacer or not. Your first post says... Press on fibre timing gear, this usually means you have the long style camshaft, but let's make sure before we attempt to answer your last posted question....
File Type: jpeg 28275A4B-5064-47B5-BBD1-196B2DC19743.jpeg (29.5 KB, 29 views)
File Type: jpeg 40A34164-24B3-4778-9B62-43D8935338B9.jpeg (26.8 KB, 25 views)
Old 02-25-2020, 07:26 PM   #15
Mart
Mart's Avatar
In that case the two bolt cover with the spacer or the three bolt cover with the three to two bolt adaptor will both give the same result. They are both designed to mate a crab distributor to a long nose (as in 21 stud with a pressed on fibre gear) cam.
Old 02-25-2020, 07:37 PM   #16
Vanspeed
Vanspeed's Avatar
So they both then must push the dizzy out 3/8 of an inch then correct? To me the 2 bolt to 2 bolt spacer is better looking than the 3 bolt to 2 bolt spacer. I didn’t know they both push the distributor out the same amount.
Old 02-25-2020, 07:39 PM   #17
JM 35 Sedan
Vanspeed, you said '46 crank gear....so I'm guessing you really meant '46 crankshaft pulley?? Or am I confused??
"Correction, I thought you were looking for max fan to distributor space for using a crab vs. helmet type distributors.
I believe the crab style distributor with spacer would give you the most space between fan and distributor, with your present engine construction.
So, if you're only talking crab distributor and long cam, the best you can be is whatever space you have using the crab and one of the two spacers, with the appropriate timing gear cover.
To get the maximum space, you would need to go with the short cam, bolt on camshaft timing gear, and two bolt timing gear cover, as I believe Mart has already said.
John
Old 02-25-2020, 07:44 PM   #18
Mart
Mart's Avatar
The distributor will only correctly engage with the cam at one spacing. Both setups should give you this spacing.
The ideal scenario would be to swap the cam and go direct two bolt and no spacer.
Old 02-25-2020, 08:35 PM   #19
JM 35 Sedan
The only advantage that I can think of at the moment, with the 2 to 3 bolt spacer, 3 bolt timing gear cover is...if your ever wanted to quickly go back to a 3 bolt helmet distributor. Which is the best way for me, since I carry both 2 and 3 bolt distributors when I'm on long distance, possibly cross-country, tours.
John
Old 02-25-2020, 08:56 PM   #20
Vanspeed
Vanspeed's Avatar
I don’t think I could ever get a stock helmet back on because of the ‘46 fan setup.
