06-08-2017, 12:13 PM | #1 |
Mounting Front Fenders on 1931
Which way are the bolts installed between the front fender and the splash aprons? When looking under the front fender, do you see the nut and washer or do you see the bolt head? Thank you. Would like to do it right the first time! Ed
06-08-2017, 12:23 PM | #2 |
Re: Mounting Front Fenders on 1931
I put the bolt head on the fender side
06-08-2017, 03:25 PM | #3 |
Ed,
I have a Marc of Excellence winning truck. When looking under the fender, the nuts and washers are visible. Judging Standards state; October 30 thru 31 - Bolts were changed to 5/16"-18 x 3/4" with a 1/2" head, a hex nut, two flat washers (11/16" x 3/4") and a 5/16" lock washer was used at each location. All fasteners were raven finished. Stew
Always one bad decision away from a good time. |
06-10-2017, 08:20 AM | #4 |
