Old 03-26-2019, 03:02 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Loadamatic Tuesday .....
Building a 49 to 53 Loadamatic today. Regular problems vacuum unit defective and shorted hot wire under the breaker plate. 3rd Generation parts supplied the cap, rotor and new vac unit. I had the NOS lead wires in stock from a older purchase. Pretty clean will post when completed and running on tester....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-26-2019, 05:41 PM   #2
WABOOM
WABOOM's Avatar
Default Re: Loadamatic Tuesday .....
Lookin good. I'm thankful that you're around to provide these services.
WABOOM is offline   Reply With Quote
Old 03-26-2019, 08:22 PM   #3
fortyfords
fortyfords's Avatar
How much vacuum do you expect out of the 94 carb, bought a brand new made in the USA carb from Joe, doesn't seem like much suction from carb. Thanks for any help, Sonny
fortyfords is offline   Reply With Quote
Old 03-26-2019, 09:10 PM   #4
40cpe
40cpe's Avatar
I've seen the specs somewhere, it produces a little less than a maximum of 4" of vacuum to the distributor.
40cpe is offline   Reply With Quote
Old 03-27-2019, 06:57 AM   #5
fortyfords
fortyfords's Avatar
Thanks for that information, its helpful.
Old 03-27-2019, 07:52 AM   #6
Pat/Ohio
Pat/Ohio's Avatar
Jim, I sent you a PM. I am having a problem with my loadamatic (I think)!
Pat
Pat/Ohio is offline   Reply With Quote
Old 03-27-2019, 12:45 PM   #7
BUBBAS IGNITION
Pat
Got it , pm sent . let me know how to help..
[email protected]
