11-12-2018, 08:22 PM | #1 |
Powered speakers for 53' Mercury
I have been working on an original radio for a 1953 Mercury that suffers from lack of volume. I have checked all the tubes on a tube tester and they all are good. This radio has a wire (that appears to be original to the radio) coming from the back of the radio that is hot (6V) when the radio is turned on. If I remember correctly some of the speakers in that era were not permeate magnets but rather electro-magnets that required a power source to amplify the radio volume signal. Does any one remember these speakers? Does anyone have a picture of that speaker? Any insight would be appreciated.
11-12-2018, 09:45 PM | #2 |
Re: Powered speakers for 53' Mercury
Either the speaker wire coils or audio amplifier output are shot. Probably the speaker coils. The audio output should be able to drive permanent magnet 8-16 ohm speakers. Jack E/NJ
11-13-2018, 03:14 AM | #3 |
The speaker with a coil winding was used as a Chokecoil for the power supply in the radio.
Itīs enough that either a coupling cap or one of the resistors is bad to give you a lower amplifiction. Amplification of the tube is set by 3 resistors/output transformer any being of from age changes it. And the bypass capacitor being dried out is also a suspect. A Schmatic so you can measure values and an oscilloscope is you best friend |
11-13-2018, 08:37 AM | #4 | |
11-13-2018, 09:35 AM | #5 |
Sorry, I don't have a solution for your problem. Out of curiosity, was the optional rear seat speaker offered for the convertible?
I know the sedans had it mounted in the package tray. If offered in the convertible where was it mounted?
11-13-2018, 10:32 AM | #6 | |
I always thought the rear window wiper was a cool option on the 52's and 53's. Not compatible with the plastic window. No rear window defroster either. But with the rear window unzipped and the side windows down, the flow through ventilation is great. |
11-13-2018, 11:02 AM | #7 | |
Even the optional wiper and rear defrosters probably didn't entice many to spend the extra few bucks (haven't seen many of them) My '51 did not come with the rear seat speaker but oddly enough it had the speaker wire installed in the rear wiring harness along with it's associated plugs.
11-13-2018, 11:13 AM | #8 |
If you check your owners manual, it lists options for that year including the rear speaker for closed cars and a speaker that was removeable and wired to the radio set for remote listening (as I recall it shows one on a picnic table). From what I remember, this was the optional rear seat speaker for the convertible. It was a plastic box with a speaker mounted inside. They were quite rare when new and probably nonexistent today.
11-13-2018, 11:46 AM | #9 | |
11-14-2018, 02:02 PM | #10 |
I'll go thru my files and try to get a photo.
11-14-2018, 08:08 PM | #11 |
have you tried to adjust the antenna trimming capacitor---a little screw usually near the antenna lead, with am car radio it makes all the difference in reception
11-14-2018, 09:37 PM | #12 |
Yes that did help a bit, (still not the same volume provided by the aux jack and the bluetooth connected to the phone). The loudest thing to come through the radio is static if you turn on a florescent light when the car is in the garage, or take the car out and drive under a high voltage line. Now why doesn't a radio station provide that kind of volume?
11-17-2018, 07:21 PM | #13 |
Sorry gents, my memory just isn't what it used to be. I went thru some old owners manuals and there is no reference to a detachable rear speaker for '53. There is one for 1950 however and that is the one I saw in a '53 convertible many years ago. Obviously not correct for '53. Next time I'll check my references before posting.
