Old 09-22-2019, 08:13 PM   #1
1930deluxe
Default shimmy or death wobble
Why is it called death wobble?
1930deluxe is offline   Reply With Quote
Old 09-22-2019, 09:10 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: shimmy or death wobble
If you have experienced it you will know. Once it starts you cannot control the steering. It gets your attention reeeeal quick.
Tacoma Bob is offline   Reply With Quote
Old 09-22-2019, 09:47 PM   #3
Bill G
Bill G's Avatar
At pretty slow speeds (fortunately) the front-end starts a rhythmic oscillation where the front tires wobble back and forth. Probably called death wobble because it can be scary, especially if you experience it for the first time. Sometimes brought on by hitting an uneven section of road, a pot-hole, or maybe just because. It can usually be stopped by yanking the steering wheel to one side quickly, but sometimes not. The root cause is worn front-end parts. Like Tacoma Bob says, if you experience it, you will know for sure. Also, if you do experience it, you will be in great company.
Old 09-23-2019, 04:15 AM   #4
old31
Why? Because you feel you will die if you keep driving. Been there.
old31 is offline   Reply With Quote
Old 09-23-2019, 04:52 AM   #5
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Because you think the front end is going to fall apart and you are going to die.
MickeyT is offline   Reply With Quote
Old 09-23-2019, 12:09 PM   #6
1931 flamingo
1931 flamingo's Avatar
Usually you have to come to a "dead" stop and then start off again.................
Paul in CT
