06-02-2012, 08:30 PM | #21 |
Re: Missing Bendix Bolt in Flywheel Housing
I had the same thing happen on my 28. I used a magnetic pick-up tool which had a felxible shaft. I slid it down next to the flywheel through the starter hole and was able to fish the parts out. Do you have 1/2 inch starter shaft or 5/8 inch shaft? The bolts are different.
Supergnat |
06-03-2012, 12:23 AM | #22 |
I use the modern starter drive in both my A,s & have had no problems.
06-03-2012, 08:17 AM | #23 |
I recently found my Bendix set-up broke as well. I called two parts stores and neither had the original parts I needed in stock, so I went with the new style drive. I'm rebuilding my carb now, so no lengthy tests on the new Bendix drive.
06-03-2012, 08:30 AM | #24 |
I have the 5/8 " shaft. I took a bolt and washer off a spare starter that I had and was ready to put all back together in just a little while. With the old bolt head and washer out of the housing, life is good!
06-03-2012, 08:38 AM | #25 |
That's great news. Life is good sometimes. I was fortunate enough to find a NOS "Special Drive" for my 28 (which has a 1/2 shaft starter) and got the car back on the road.
10-03-2016, 04:13 PM | #26 |
10-03-2016, 04:20 PM | #27 |
I use two neodymium magnets work awesome,on the back side of flywheel,only problem getting magnet off. works great,thought had to take whole car apart.
10-03-2016, 07:08 PM | #28 |
I just went thru a fallen bolt. The replacement lock washer was hard to bend as it was quite thick. I beat it into position. I'm hoping the old bolt will stay at the bottom.
02-19-2017, 08:09 PM | #29 |
My 29 Bendix Screw broke off and I just recently find out, where can I buy the bolts and washers locally in Orange County? Do I have to change the bendix spring as well? Thanks!
02-19-2017, 08:20 PM | #30 | |
BTW, in this age of B.S. political correctness, can we still call the spark RETARDED? |
02-22-2017, 01:10 PM | #31 |
Thanks!
02-22-2017, 01:46 PM | #32 |
You might also consider replacing the bendix drive with one of the new "modern bendix drive" units. Bratton's has one on p.75 ($35.25) of their 2016 catalogue. This type of drive unit does away with future prospects of dropping starter bolts down inside the flywheel housing. Good luck regardless.
02-22-2017, 06:47 PM | #33 |
02-22-2017, 07:12 PM | #34 | |
More modern cars don't seem to have a problem with them... Last edited by Y-Blockhead; 02-22-2017 at 07:20 PM. |
02-23-2017, 04:47 AM | #35 | |
Since personally breaking 2 made in India barrel drives and seeing two others smashed, I have had no trouble with the Weldon brand drives made in USA, fitted in both my 6 volt cars, one of which puts a lot of strain on the starter, being 100 psi cranking pressure SAJ in NZ |
02-23-2017, 08:22 AM | #36 | |
02-23-2017, 03:13 PM | #37 | |
02-23-2017, 04:52 PM | #38 |
I had one for about 8 or 10 thousand miles, and I discovered the bolt was loose, but not broken. Due to fordbarn input that the gear isn't always a full engagement of the ring gear, I went back to the original. My assessment, for what's it's worth, is the starter needs to be pulled every ? Several thousand miles and inspected/ repaired. I'm getting " spring ready now, and that's on my list.
02-23-2017, 09:17 PM | #39 |
My modern starter drives are American Made!
Don Snyder |
02-24-2017, 10:58 AM | #40 | |
http://www.vanpeltsales.com/FH_web/i...prices-pg3.htm John |
