04-19-2012, 06:03 PM | #1 |
Fitting
Can anyone tell me why a fitting with ferrules is used in the fuel line but a double flare compression type fitting is used in the brake system? Can they be interchanged? Thanks
04-19-2012, 06:13 PM | #2 |
Re: Fitting
I used standard 1/4 inch steel brake line for fuel line and it has worked great for the last 30 years.
04-19-2012, 07:45 PM | #3 | |
Re: Fitting
You can use inverted flares in a fuel system. In fact, in my modified cars I do just that. You should not use ferrule/compression fittings in a brake system for the reason noted above. |
04-19-2012, 08:37 PM | #4 |
Re: Fitting
www.fordcollector.com |
