07-19-2017, 01:10 PM | #1 |
card adjustment
When turning the choke to set mixer where should one start?
07-19-2017, 01:45 PM | #2 |
Re: card adjustment
Start cold 1 1/2 open and close till it runs good while it (engine) warms up.
BTW mixer = GAV |
07-19-2017, 02:57 PM | #3 |
Re: card adjustment
My car runs best at 1/8 turn after warming up. When it's warmer out I open it 1/4 further open to start, when colder I open it 1/2 turn further open to start.
07-19-2017, 03:15 PM | #4 |
Re: card adjustment
Is this a Zenith Carb?
07-19-2017, 03:30 PM | #5 |
Re: card adjustment
No, it's a Marvel.
Bob |
07-20-2017, 11:55 AM | #6 |
Re: card adjustment
07-20-2017, 08:32 PM | #7 |
Re: card adjustment
OH, on the GAV, with it closed, if it starts/warms up/runs OK, just forget it exists!
Bill Simple
07-20-2017, 09:42 PM | #8 |
Re: card adjustment
07-21-2017, 09:03 AM | #9 |
Re: card adjustment
Great Carb. I have been using and rebuilding them. Check this thread out.
https://www.fordbarn.com/forum/showthread.php?p=878859 |
07-21-2017, 10:05 AM | #10 | |
Re: card adjustment
07-21-2017, 10:17 AM | #11 |
Re: card adjustment
Renners Corner ive heard has parts.
1929 Model AA - Need long splash aprons! |
07-21-2017, 10:17 AM | #12 |
Re: card adjustment
Renners Corner has most of the needed parts for the Marvel, Allstate and others (same basic design); the GAV needle gasket they supply is rubber-like and may make the adjustment tight. Not sure if leather was originally used ? Also, try to find a viton tip float needle for the ethanol gas as stated in other threads. The Grose jet style with metal ball may not seat properly.
07-21-2017, 03:03 PM | #13 |
Re: card adjustment
Steiner Tractor has a viton tipped float valve that fits most Marvels.
