10-20-2017, 12:44 PM | #1 |
Hard brake pedal
Hey ya'll, Had a hard brake pedal with no 1" free play. 28' special coupe. Had a brake job done a year ago. All new guts on the backing plate, (I mean everything) and new cast iron drums. Decided to do a better brake adjustment then what had been done. The brakes work great now. Just like the book. Full on - rears lock & fronts grab, no pull left or right. Had to change rod lengths to get it that way and the brakes seems a little softer. But I have no free play. !/4" at the most. I can drive it like this fine, but what would cause that? Linkage to tight?? Return springs are working, can't pull the pedal back any further. It has a N/S cross shaft, correct 15 degree tilt on actuator arm. I used a brake board for adjustment. Could barely get the pedal to move the 2" required. Is that normal? I read some where that ol' Henry had an inch of free play designed into that whole mess of marvelous mechanical lingage. I guess I lost mine some where. Any ideas are welcome.
Ivan |
10-20-2017, 01:44 PM | #2 |
Re: Hard brake pedal
You don't really need 1" of free play, just a little is enough.
10-20-2017, 01:50 PM | #3 |
Isn't 1" for the clutch pedal ? The brakes are around 1/4" to 3/8" if memory serves for pedal slop. Also,check the brake light operation when the pedal is depressed. The pedals should align with each other when retracted.
10-20-2017, 03:30 PM | #4 |
Back off each brake adjuster the same amount, go for a test drive :-)
10-20-2017, 03:49 PM | #5 |
We have always adjusted to one inch or so of peddle play. Good point about brake light. Not enough play and light might not go on. Enjoy.
10-20-2017, 05:20 PM | #6 |
Purdy Swoft & I both wrote LENGTHY articles on proper brake adjustment. FORGET the BOARD, it's USELESS, who in the WORLD would want the rear brakes locking up FIRST (DANGEROUS!) I don't care about what Henry "thought"----- Bill Opinionated
10-20-2017, 05:34 PM | #7 |
10-20-2017, 08:33 PM | #8 |
Well I did have a problem with the brake light switch until I elongated the screw holes for mounting it. Pedals are uneven, brake pedal being 3/4" closer to seat. I think I'll readjust for front and rears coming on together and call it good. She stops, and I don't worry to much about the idiot pulling out in front of me like I don't exist.
Ivan |
10-20-2017, 08:52 PM | #9 |
Ivan. Would your 28 happen to be a VERY Early 28? One that has the four wheel braking system? The emergency brake handle is next to the driver side cowl? I'm new to the site and I posted yesterday for anyone with an early model 28. Desperate for info on that brake system. I can't seem to find anything as of yet. Bought all the books and all they say is that the early model has what I already know I have. No specific info. Called several parts suppliers and they all say "the 28 brakes are all the same" They are not. Any help? Harold.
H Barnett |
10-21-2017, 03:55 AM | #10 |
You adjust the early 28 service brakes just the same as the later Model A brakes. Don't worry about the parking brake adjustment, as that just pulls all 4 service brakes the same as the foot pedal does.
10-21-2017, 08:08 AM | #11 |
As long as your brakes are not dragging, why do anything. You can screw up brakes if you keep playing with them.
10-21-2017, 10:38 AM | #12 |
Sorry, but mines the other type. Handle behind the shifter. I think the difference you have going is your emergency brake and service brake use the same brake shoe(lining) on your rear brake. Brake setup should be the same.
Ivan |
10-21-2017, 06:21 PM | #13 |
OK, so you have the same as my 28 brakes. Just adjust them as well explained in the Service Bulletins.
10-22-2017, 11:42 PM | #14 |
I understand the actuators front and rear are different lengths to make the rear come on first. Not sure how much can be reversed because of the engineering. I think it was Kevin in New Jersey that posted about this years ago
