Old 02-29-2020, 04:51 PM   #1
Don
Don's Avatar
Default Valve clearance for 38 21 stud
I’ve read a lot on how to do valve but have not found anywhere we’re a person has given the correct settings ,these are non adjustable valves!have all the tools so going old school all I need is the lash settings. ,thanks
I think I have used .012 I and .014 on ex
DON P
Don is offline   Reply With Quote
Old 02-29-2020, 05:42 PM   #2
estout81
Default Re: Valve clearance for 38 21 stud
My old Motors manual say's .012I&.014EX.
estout81 is offline   Reply With Quote
Old 02-29-2020, 05:53 PM   #3
Don
Don's Avatar
Thanks that’s what I’m going with !!!!!
DON P
Old 02-29-2020, 08:32 PM   #4
JSeery
JSeery's Avatar
It really depends on the cam and the cam grinders specifications. If it is stock, then it is Fords specifications.
Old 03-01-2020, 09:05 AM   #5
big job
big job's Avatar
In .012 Ex .014 too tight just take time grinding the stem. I made a fixture just a piece
of pipe that fits the valve stem and clamped that to the side fine grinder wheel. As I grind and rotate the valve to the wheel just nipping it check & repeat. Lash too loose, then you
have to reface the valve and or the seat, to set it deeper.
big job is offline   Reply With Quote
Old 03-02-2020, 07:24 PM   #6
Talkwrench
Talkwrench's Avatar
If a standard cam I went ; int .010 -.012 exh .012 -.014 , Its been 18 months now daily driving , quiet , no problems. Spring were progressively wound and slightly heavier than stock [ Gary's one piece valve set]
