12-29-2012, 03:00 PM | #1 |
shut off valve packing install
can this packing be installed without removing valve from tank?
closing the valve lever has very little resistance but seems to hold the gas back , so i think new packing is nesessary. have removed line between valve and sed bowl but afraid to disconnect valve from tank in case it damages threads or worst. 30 t sed fred |
12-29-2012, 03:24 PM | #2 | |
Re: shut off valve packing install
Pluck |
12-29-2012, 03:32 PM | #3 |
Drain the tank and DISCONNECT the battery. JMO
paul in CT |
12-29-2012, 04:45 PM | #4 |
When using one wrench to unscrew the valve you put a lot of side force on the valve. It's best to use two wrenches 180* apart, or if you must use just one wrench grab the valve and wrench with one hand to try to take some of the side force off as you push the wrench around with the other hand.
12-29-2012, 05:04 PM | #5 |
If you're going to remove the valve, have a bucket ready to catch the small amount of gas left in the tank. Also, disconect the battery.
12-29-2012, 05:10 PM | #6 |
12-29-2012, 05:22 PM | #7 |
Fredski,
If you're not concerned with originality, hardware stores offer a perfect fit, petcock type valve, that never fails for under $4.00. Take your old valve for a sample & don't forget to install the standpipe filter in the top of the valve!! It is a GODSEND!! Bill W.
