Old 12-04-2019, 01:30 PM   #1
GPierce
GPierce's Avatar
Default High compression head vs cooling
Does using a high compression head create more heat for the cooling system to remove?
I know the heat of compression will be higher.
GPierce is offline   Reply With Quote
Old 12-04-2019, 01:34 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: High compression head vs cooling
More heat in the engine but the cooling system does run cooler fron what I have read.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 12-04-2019, 01:43 PM   #3
alexiskai
alexiskai's Avatar
I thought the whole idea was that higher compression makes the combustion more efficient, transforming more energy into power and less into waste heat. So it would create less heat (unless your snazzy new HC head causes you to drive the car faster/longer).
Old 12-05-2019, 09:05 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
In my experience, the engines run cooler due to more efficient power stroke combustion.
Bob Bidonde
Old 12-05-2019, 09:29 AM   #5
rotorwrench
rotorwrench's Avatar
Combustion efficiency is only one aspect of heat generation. It is also affected by the amount of power that is pulled by the engine or how long it sets at idle. Cooling systems will draw the heat away if they are efficient but setting at idle has less air flow than running down the road. If you consistently pull heavier loads or try to get higher speeds than normal then more heat will be generated. With more power there is always more heat under load. Normal driving will have less affect and the difference may be negligible.
Old 12-05-2019, 09:50 AM   #6
old31
When I installed my 6.1 head I had overheat problems at long highway speeds, as before I did not have a problem. I had the radiator cleaned out and flow tested and the shop said it was good. I reinstalled it and I had the same issues.
I installed a Bergs radiator and that solved the problems. Today I can run in 95 degree temps at 55 mph all day long.
old31 is offline   Reply With Quote
Old 12-05-2019, 02:02 PM   #7
Russ/40
Russ/40's Avatar
My experience mirrors Old31's. The Berg's a terrific radiator. My truck runs so cool I can't really make an observation for the 6.1 head other than it feels like 60hp, not 40. I suppose a light truck has something to do with that. I'm elated with my truck now.
Old 12-05-2019, 08:23 PM   #8
gary678*
I have a 5.5 head and a 160 degree thermostat with a 50/50 blend of antifreeze. On a hot summer day up a long steep hill on NY's Bear Mountain (2.0 miles+) at 45 MPH the temp went to 170; on the downhill side it dropped to 150. Otherwise it runs at a steady 160. My guess is that if you develop a heating problem that the cause is probably not the head but something such as a blown head gasket with the loss of coolant, or simply a deficient radiator or water pump, or more. Gary
gary678* is offline   Reply With Quote
Old 12-06-2019, 10:08 AM   #9
old31
I agree with Gary.
I am also running 50/50 mix but with a 180 tstat.
Old 12-07-2019, 07:02 AM   #10
chap52
chap52's Avatar
6:1 Snyders head, 160 thermostat, 50/50 mix. Runs cooler than it did with stock set-up. Chap
Old 12-07-2019, 07:28 AM   #11
Alaska Mike
As a sort of other question about high compression heads, I have been considering one, but was told that it is sometimes difficult to get the engine to idle properly with a high compression head. Have any of you experienced that problem?
Alaska Mike is offline   Reply With Quote
Old 12-07-2019, 09:49 AM   #12
old31
Alaska I have not had any idle problems since I installed the 6.1.
One thing I have noticed since I did my engine work (larger intake valves, touring cam, model b carb, bored intake, bored cylinders, v8 clutch, lightened flywheel) is that I have lost the famous model a chug chug chug at idle. I do miss that sound. The car sounds more like a modern car.
But the gain is well worth the idle sounds of chug chug chug.
Old 12-07-2019, 10:43 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
I'm still running 5.9 compression heads on some of my model A's and they run cooler than original .
Old 12-07-2019, 01:54 PM   #14
Russ/40
Russ/40's Avatar
I can't give any credibility to that. I think its non-sense. Just take the time to make carb adjustments, you should make with any equipment change.
Old 12-07-2019, 02:50 PM   #15
wensum
wensum's Avatar
Our motor has a 7:1 head and considerably lightened flywheel plus dual Strombergs and the motor can idle as smoothly and slowly as a standard Model A.
wensum is offline   Reply With Quote
Old 12-07-2019, 05:05 PM   #16
Purdy Swoft
Besides the 5.9 head , I run the super street Winfield 3/4 race cam , lighter model B flywheel , dual updraft model B carburetors and a few other minor mods . My model A idles smoothly and has the normal model A cackle at idle with the spark retarded . My car may not idle exactly as slow as a completely stock engine but it will idle purdy slow
Old 12-07-2019, 08:08 PM   #17
dumb person
dumb person's Avatar
Depends if your head is alloy or iron.
"Alloy is for boiling water.
Iron is for power."
It was told to me that the alloy heads conduct the heat into the water faster, which is true. Hence robbing power & creating heat in the cooling system.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 12-07-2019, 09:57 PM   #18
Purdy Swoft
My heads are all cast iron . I prefer cast iron for durability , A lot of people have been running the Thomas finned aluminum heads for years , the aluminum heads must be doing some good or people wouldn't continue using them . Hot rods with flathead V8s have been using aluminum heads forever . As expensive as higher compression heads are , I want mine to last as long as possible . I've never had a problem with cast iron .
Old 12-08-2019, 10:42 AM   #19
old31
Purdy and Wen, like me, have you lost the Model A chug chug chug at slow idle, or do you still have it.
Old 12-08-2019, 12:16 PM   #20
Purdy Swoft
Mine still has the model A cackle or chick ah lunk as I call it at idle. They might not idle exactly as slowly as original , but they idle pretty slow with the spark retarded .
