02-21-2012, 05:37 PM | #1 |
Taking apart 1936 dash switch
Hi Barners,
Is there a trick to getting the bezel off the front of the "36 dash switch? There are 4 very delicate looking tabs on the back. They look like they will break on the first bending. I want to send the bezel out to the plater. Thanks, Bruce
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford |
02-21-2012, 08:29 PM | #2 |
Re: Taking apart 1936 dash switch
Bruce-
I am not familiar with a 4-prong dash light switch the only ones I have seen are 2-prong. At any rate, you need to line-up the prongs with the dash indentations, squeeze the prongs together and push the unit out. Hopefully, the prongs will slip through the indentations. Usually they don't go very easily. Often the prongs break in the process. If this happens you need to come up with a Plan B to put it back in. The most common method is to insert the switch in the dash, slide a small piece of heater hose over the switch and tighten the hose with a clamp. The clamp spreads the hose and tightens the switch to the dash. This works but it doesn't look pretty on the backside. Unfortunately, there are no repos being made and used ones ('35-'37 use the same switch), often sell for over $100. Good luck. Tom |
02-21-2012, 09:01 PM | #3 |
There not an easy fix. ken ct.
02-21-2012, 11:25 PM | #4 |
Sorry if I was unclear!!!! My wife says this occurs often.
I have the switch out of the dash. I had no problem there BUT I can't get the bezel off to send out for re-chroming. I've tried wiggling it and pulling it back to no avail. There are 4 small tabs on the rear of the switch itself. Are they the key. If yes, how not to break them off making the dswitch junk. Bruce
02-22-2012, 07:24 AM | #5 |
Let's try todays Barners
02-22-2012, 07:31 AM | #6 |
Gary. |
02-22-2012, 05:55 PM | #7 |
You have to bend the small retaining tabs the bare minimum to remove the end cap and the internals. The knob has to be cut off to remove the square shaft. If the two electrical terminals appear to be getting close to each other the end cap does warp. I cut a small piece of plastic (from a large, black, electrical wire wrap) and place it between the terminals to keep them apart and this will make the switch work better.
