Old 08-10-2020, 10:52 AM   #1
Tom's36coupe
Tom's36coupe's Avatar
Default Radiator mounting, 2 holes?
I have two sets of holes on the frame for mounting the radiator, does it make a difference on which one I use and how the grill bolts on? Picking up my grill assembly tonight. Seems like it was a tight fit before when I was removing my distributor. Thanks
Tom's36coupe is offline   Reply With Quote
Old 08-10-2020, 11:00 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Radiator mounting, 2 holes?
I don't know the answer for sure on which set of holes to use. Can you see any wear marks that might give an indication on which holes to use? My 40 also has 2 pair of holes.
I just used the holes that provided the best fit.
Old 08-10-2020, 11:03 AM   #3
Tom's36coupe
looks like the set closer to the motor has some wear on that hole, other is nice and round. That must be it?
Old 08-10-2020, 11:33 AM   #4
V8ER
The radiator mounts to the rear holes. Check the Private Message that I sent to you.
V8ER is offline   Reply With Quote
Old 08-10-2020, 11:41 AM   #5
DavidG
DavidG's Avatar
Unless it is a pickup.
Old 08-10-2020, 11:46 AM   #6
19Fordy
19Fordy's Avatar
Will the holes you use make it easier to install lower radiator hoses? Seems like a small point, but you never know. Even fan clearance may be effected. Check it all out on a trial fit with empty radiator.
Old 08-10-2020, 11:54 AM   #7
jimvette59
jimvette59's Avatar
The holes will determine the where the hood will line up.
jimvette59 is offline   Reply With Quote
Old 08-10-2020, 12:18 PM   #8
DavidG
DavidG's Avatar
And the grille and its relationship with the front fenders as the grille is attached to the radiator.
Old 08-10-2020, 05:42 PM   #9
Tom's36coupe
V8ER, rear holes as in closer to the engine? Thanks
Old 08-10-2020, 10:45 PM   #10
Don Rogers
Don Rogers's Avatar
Here's a modified diagram showing the difference in radiator mounting between passenger car (68) and commercial vehicle (67)
Don Rogers is offline   Reply With Quote
