07-02-2012, 04:18 PM | #1 |
Pick up cabs
Did Ford use the same pickup cabs in the thirties? How can you tell the difference?
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
07-02-2012, 05:13 PM | #2 |
Re: Pick up cabs
Cabs were the same on most trucks except COE for any given year, but fenders were different and some interior features were different.
Alan |
07-02-2012, 06:15 PM | #3 |
Re: Pick up cabs
There were similar years like 32 thru 34, 35 & 36, 38 & 39, 40 & 41, 42 thru 47. The 37 was close to the 36 but had some items that went toward 38 too. Some folks have sucessfully changed cabs with different year models but there is usually some modifications that have to be done to get them to work. Some are way more similar than others. You just have to scrutinize the different body lines to make certain they will work. If you have any particular years in mind just specify and someone can usually tell you whether its feasable and what has to be changed.
07-02-2012, 11:20 PM | #4 |
Re: Pick up cabs
When did Ford pick up cabs stop having the almost vertical firewall? Did the 34 pickup have the same type of firewall as the 34 car?
07-02-2012, 11:34 PM | #5 |
Re: Pick up cabs
1st question:1935
2nd " no |
07-03-2012, 11:16 AM | #6 |
Re: Pick up cabs
