03-11-2012, 03:44 PM | #1 |
McCullough Super Charger V/8 Ford
I just bought a McCullough Super Charger mounted on a Flathead V/8 intake manifold. I did not get the crankshaft pulley or the belt tension pulley. I will appreciate all comments and help. I see there are oil line hook-ups and cooling line hook ups. I really do not have a clue! I searched the internet and some other forums and there was not much information. There is a lot for Studebaker super chargers but not much for Flathead Fords. I have seen a few pictures but that is all.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
03-11-2012, 03:51 PM | #2 |
Re: McCullough Super Charger V/8 Ford
You have a couple replys on the HAMB but pictures would realy help. Gary
03-11-2012, 04:28 PM | #3 |
It is a model 38F85. I will post some pictures tonight when I go to town.
03-12-2012, 05:24 AM | #4 |
I've got a McCulloch that I'm just finishing a rebuild on. I can e-mail some pics to you but I don't know how to post them here. KGS
03-12-2012, 09:02 AM | #5 | |
My email address is [email protected] I sure appreciate your offer. I sent a private message too. Thanks
03-12-2012, 09:31 AM | #6 |
03-12-2012, 10:14 AM | #7 |
Sturgis: What engine are you going to put this on?
I am putting one on a 35 21 stud. Have made most of the pieces as mine was not as complete as yours. We made the crankshaft pulley as well as the generator mounting bracket that puts the generator mid engine on the drives side. There use to be a site v57 that had a lot of information but I can't find it any more. I printed all the information on the site and could copy what I have and send it your direction. Send me a PM with your address. We also used truck double pulley water pumps on the 35 heads. Dave/Green Bay |
03-12-2012, 11:07 AM | #8 |
Here is some more good information and pics from a while back. Ed
http://fordbarn.com/forum/showthread...t=supercharger |
03-12-2012, 11:09 AM | #9 |
03-12-2012, 11:28 AM | #10 |
I have one of those monsters. Working on a car now to put it in.
You have the 2nd year of production, probably an early 1938 one. The numbers in your tag mean that it was built in 1938 for a Ford, 85 Horsepower (38F85) This is a picture of what they originally came with. Finding the Triple crank pulley and water pump pulleys will be next to impossible. Here is my 1937 McCulloch. Here is a test fit on my 40 flatty before I installed the double pulleys. The generator mounted further back on the head and ran off the rear pulley. I plan on using a double pulley generator as my idler arm to hold the belts tight. This is a photo of an original install with the triple belts.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 03-12-2012 at 11:46 AM. |
03-12-2012, 01:21 PM | #11 |
Drool. I have always thought these damn things were the coolest.
03-12-2012, 01:35 PM | #12 |
I just made a copy of the order form, wrote out a check for 2 units. I hope they get it and I can finish my project.
03-12-2012, 01:44 PM | #13 | |
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
03-12-2012, 04:20 PM | #14 |
Sturgis 39 and Dave/Greenbay, I'll be in touch to kick this stuff around but it looks like my 39M or F is almost totally different than your McCulloch's. Check your e-mail. Ken
03-12-2012, 04:25 PM | #15 |
The 1937 and 1938 were different. In 1939 McCulloch started including the intake as well.
My theory is that the 1937 and early 1938s were for Ford cars with the water pumps in the front of the head. When Ford went to center outlet heads, they had to relocate how the supercharger was cooled, and where the generator bracket goes. This is the earliest style that uses the stock Ford intake. And the 1939 uses the McCulloch supplied intake, and a different water neck. Also the aluminum casting has an Arrow on top and the name plate is mounted to the side of the gear box, where the earlier is smooth with name plate mounted on top.
03-13-2012, 09:25 PM | #16 |
Has anybody installed a larger crankshaft pulley or a smaller pulley on the blower. A smaller pulley on the blower would increase the blower rpm and keep the water pumps running at the same speed. Just thinking or day dreaming.
I want to thank everybody for their replies. This going to be a fun project. THANKS AGAIN
03-14-2012, 05:31 AM | #17 | |
What all have you found as the differences in 37 and 38 models?
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
03-14-2012, 09:34 AM | #18 |
Has anyone ever measured the Boost curve?
03-14-2012, 01:03 PM | #19 |
Did quite a bit of experimenting years ago. Don't have any numbers but not near what was advertised. I found a couple on some old 40s fleet flatbed trucks setting out in a field back in the 60s. Bought them, took them home and used one on a hotrod. Didn't care for it but today anything flathead nostalgia is hot......
03-14-2012, 01:23 PM | #20 |
I've got what I think to be an early 37 one and the gusset on the snout just behind the mount where the generator would normally go is a square plate. I've noticed on almost all of the other 37-38 style ones that the gusset is a triangle plate going from the front mount up to the snout.
Someone cut a chunk out of my square plate in the past to clear something, but I'm not sure what for. A heater hose? spark plug wires? Not sure. I was told my McCulloch came out of a Hopped up 1940 Ford coupe that used to drag race around florida in the 50s.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 03-14-2012 at 01:45 PM. |
