Old 01-26-2011, 10:54 AM   #1
sturgis 39
Default Ford 12 volt system
When did Ford go to a 12 volt system? When did Ford go to negative ground?
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 01-26-2011, 11:04 AM   #2
V12Bill
V12Bill's Avatar
Default Re: Ford 12 volt system
1956
V12Bill is offline   Reply With Quote
Old 01-26-2011, 11:26 AM   #3
Vic Piano
Vic Piano's Avatar
As I understand it, some of the early Ford cars equipped with electrical systems (starter, lights, etc.) were negative ground. Not sure when they switched to positive ground 6 volt but they did convert to 12 volt negative ground in 1956.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 01-26-2011, 12:53 PM   #4
Bruce Lancaster
They went to positive ground in 1928, back to negative 1n 1956 with 12 volts.
Bruce Lancaster is offline   Reply With Quote
Old 01-26-2011, 12:58 PM   #5
Mr 42
Mr 42's Avatar
Lights, starter, dont care about polarity.
if you have a heater motor if will care so switch the cables.
Ignition coil does care about polarity (it will work with less performance) but if you go 12 volt you will change the coil anyway.
The condensor i supposed care to but i seams to work anyway.
But its safer to change to one from a 12 volt negative earth 8 cylinder engine.
Mr 42 is offline   Reply With Quote
Old 01-26-2011, 01:20 PM   #6
sturgis 39
The reason i asked was because a guy on the hamb is having trouble with his 56 Ford. He said it is six volt positive ground. I said Ford went to negative ground and 12 volts in 55.
Old 01-26-2011, 06:07 PM   #7
Rem
Rem's Avatar
I'm positive (LOL) that they were still 6V in '55 - at least my F-250 was before converting it to 12V -ve.
Oh, and I fitted a '56 F-100 heater and that had a 12V motor.
Rem is offline   Reply With Quote
Old 01-26-2011, 06:16 PM   #8
Barlea
The guy on the HAMB is positive it's a '56, and negative to the probability his car is actually a '55? ..B.
Barlea is offline   Reply With Quote
Old 01-26-2011, 08:02 PM   #9
sturgis 39
I sent what was posted on the Ford Barn. He has not posted after my posts. I have completed my mission.
Old 01-29-2011, 12:11 AM   #10
40 Deluxe
Why would the thread be deleted? Facts are facts!
Old 01-29-2011, 07:04 AM   #11
sturgis 39
Ethanol is a political issue. It takes more energy to make than it produces. It increases food prices and propane prices for home heating. The mpg is less. We would be energy ahead to burn the propane in vehicles instead of spreading on the ground as fertilizer to grow corn. It has created a big government bureaucracy. Tax money is used to subsidies the program. The actual cost per gallon is about $22.00. It is like the alchemist using 1.25 ounces of gold to make one ounce of gold.
Old 01-29-2011, 09:23 AM   #12
tom/illinois
You are 100%correct.
tom/illinois is offline   Reply With Quote
Old 01-29-2011, 10:28 AM   #13
mtflat
mtflat's Avatar
Ethanol has polarity???? Where'd he go...........?
40 deluxe, the red part of sturgis' post is his tag and isn't part of this discussion.
mtflat is offline   Reply With Quote
Old 01-29-2011, 04:21 PM   #14
Jack E/NJ
Jack E/NJ's Avatar
mtflat wrote>>>Ethanol has polarity???? >>>
Of course it has polarity! Maybe not as much as water. But a lot more than gasoline. Geez, I thought everybody knew that. 8^)
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
