10-05-2018, 10:19 PM | #1 |
Clutch Release Fork Positioning
With my restoration process I always seem to come upon a situation where it's not covered in the many restoration books I have.
My question has to do with the positioning of the release fork that I already have attached to the release fork shaft. It looks Okay to me, but I just wanted to get your input before I button up things. I found out I have a few different styles of release forks. The one which I have currently attached to the release shaft has a flat spot on one end and a rounded end on the other end. The way this release fork is positioned would have it come into contact with the throw-out bearing hub would be on the flat end of the release fork. Does this look right in the way the release fork is installed that would work properly, or should it be reversed on the shaft? Thanks in advance to all that provide input to my question. Last edited by California Charlie; 10-05-2018 at 10:59 PM. |
10-06-2018, 12:20 AM | #2 |
Re: Clutch Release Fork Positioning
I think you have it on the shaft backwards.
Tom Endy |
10-06-2018, 12:41 AM | #3 |
Tom's picture looks normal, but I've never seen a fork as you have pictured.
Do you have a fork like Tom's? |
10-06-2018, 08:18 AM | #4 |
I think I have a release fork like Tom's. Perhaps that would be the real answer that I'm looking for. Thanks!
10-06-2018, 02:53 PM | #5 |
