Old 01-18-2018, 11:10 AM   #1
Questus
Questus's Avatar
Default GERTRUD 1928 from northern part Germany ready to go
Hi Folks
first of all..... Pictures - telling more than words.
the end - fini - finish - all over now - waiting for spring
regards Questus
Questus is offline   Reply With Quote
Old 01-18-2018, 11:51 AM   #2
Russ/40
Russ/40's Avatar
Default Re: GERTRUD 1928 from northern part Germany ready to go
Very nice indeed!
Old 01-18-2018, 11:59 AM   #3
JDupuis
JDupuis's Avatar
Two thumbs up.....way up. Early spring? Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-18-2018, 12:17 PM   #4
henry's 31
Very nice work, now continue to enjoy your A while you drive it. Thanks for sharing!
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 01-18-2018, 12:24 PM   #5
FordTudor1931
FordTudor1931's Avatar
Great job! Spring has to be right around the corner.
Was your car built or assembled in Germany? The Berlin factory did produce some Model A before the move of the factory to Cologne in 1929.
FordTudor1931 is offline   Reply With Quote
Old 01-18-2018, 01:06 PM   #6
Floats
Floats's Avatar
Well done Questus,
Enjoy the spring and summer in a few months.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 01-18-2018, 01:08 PM   #7
Terry, NJ
Terry, NJ's Avatar
Looks Great! Is that water connection on the side of the block aluminum? That two blade fan, Is it steel or aluminum? If it's steel, take it off and replace it with a new cast aluminum. Those fans are getting old and they sometimes let go and make a real mess out of your engine compartment and hood.
Good Job, Terry
Old 01-18-2018, 01:14 PM   #8
1930-Pickup
Wunderbar!
Have you driven it around a bit to test for any issues?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 01-18-2018, 02:02 PM   #9
Questus
Questus's Avatar
Thanks to all experts in USA
YES, I have had driven with here when ever I can get in the weather at wintertime
(english ok?)
The fan is a new one, the inlet aloy too, the connecting rods,
the camshaft teeth and so many other parts
imported from Georgia.. (you know the Company, I think so....)
Gertrud is a Canadian build and are watching the daylight since June 28
here are partytime to the 90 ths birthday in june
the seats upholstery are from cologne... germany
but now.... the mice make gymnastics at the breadbox at home !
regards Questus
Old 01-18-2018, 02:11 PM   #10
SeaSlugs
SeaSlugs's Avatar
Very nice! FYI your lower water pipe is installed backwards and I think you have the incorrect upper water neck for a 28/29.
The water petcock should stick straight down and be the lowest point in the cooling system so it drains all the water.
The upper neck looks too tall so the angle between it and your radiator is off but i might be looking at it wrong.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-18-2018, 02:25 PM   #11
3.6rs
3.6rs's Avatar
Originally Posted by Questus View Post
...waiting for spring
regards Questus
Spring ?? Why not now ?
Is there snow in your part of Germany
10°C today, dry weather. Tomorrow 7-8°C.
3.6rs is offline   Reply With Quote
Old 01-18-2018, 02:32 PM   #12
Questus
Questus's Avatar
every Thing is quite ok in your words - I knew that since rebuilding
BUT
If you are stay far away from your Country....
and you are mounting the engine than it "knacks" on the bolds....
70 Newtonmeter !!
you can buy a knew one 10 $ adition customs and fedex 150 $
for me two much, eBay Gerrnany 10 € the wrong outlet and I must wait for the next order to Georgia..... I cant get anything of "A" parts from my country
Questus
Old 01-18-2018, 02:39 PM   #13
Questus
Questus's Avatar
to belgique
snow 15 cm zero degrees Celsius 8/8 Clouds
985 hPa Baro is climbing up a Little bit since 3 hours
after hurricane Friderike...... near hamburg
nothing to ride an early A
Old 01-18-2018, 07:42 PM   #14
Mike Peters
Mike Peters's Avatar
We toured NE Germany last summer, including Preetz and Prohn near Stalsund, which is about one hundred miles east of Lubeck on the Baltic Sea. My great grandparents immigrated to America from Preetz in 1870, so we were curious about where they had originated from.
Congratulations on finishing your Model A! Nice work. I'm working on a 28 Phaeton in my shop this winter.
Mike Peters is offline   Reply With Quote
Old 01-18-2018, 07:50 PM   #15
wingski
wingski's Avatar
Gertrud, you are looking great. I hope you really enjoy Spring when it comes.
Mike
wingski is offline   Reply With Quote
Old 01-19-2018, 12:16 AM   #16
3.6rs
3.6rs's Avatar
... you can buy a knew one 10 $ adition customs and fedex 150 $
Questus
There are suppliers in UK. Cheaper shipping then USa and there are no custom and import taxes (for now ! untul the Brexit !)
Old 01-19-2018, 03:01 AM   #17
burner31
burner31's Avatar
Engine looks great, did you do the seats yourself?
Keith
Shawnee OK
'31 SW 160-B
Old 01-19-2018, 05:26 AM   #18
Questus
Questus's Avatar
Moin Moin Keith,
yes everything by my own (without sewing)
I used: 2 sleeping bags outdoor and 2 square meters 120 mm foam material inside the springs to stablilized the functions
last refitt inside and engine - Summer 1952 - (I´m 1 year old become even more dense)
see more pics
------corpus seat left---------------- RUST --------------------last year before
regards
Old 01-19-2018, 06:28 AM   #19
Floats
Floats's Avatar
3.6rs,
I beg to differ.
I am visiting in the UK at the moment and it seems to me the UK prices are, US prices + shipping + import duty + profit + UK VAT = 3 X US prices
Example, a set of Model T front wheel bearings quoted this week is about $240 US(£170). The same set in the UK, I eas quoted £350($486US)
Please correct me if I am mistaken and please give us the names of the UK vendors.
Regards
Chris
Cape Town
Old 01-19-2018, 07:27 AM   #20
Questus
Questus's Avatar
This is also my experience
