06-28-2014, 02:21 PM | #1 |
Emergency brake question again.
Sorry guys about putting something on again about my e brake problem. But dumb old me still can't figure it out. Here are some more pictures and questions. Such as-do I have the lining set up the correct with the toggle links? Or do I have it upside down? Should the space between the edge of the lining where the toggles tie in be greater toward the car or out?
I did have the toggle pins with the heads out but I did have the narrow space on the linings in toward the car. This is on the right rear wheel and so far I have not been able to find a picture of a right wheel set up. Tom posted a left wheel on the last post I had and thanks Tom. Sorry guys if I wasn't so lazy, I would take the left drum off again and see how it was set up. But I just got it all greased up and hate to do that.
Fred Kroon 1929 Std Coupe 1929 Huckster Last edited by Fred K-OR; 06-28-2014 at 02:35 PM. |
06-28-2014, 03:47 PM | #2 |
Re: Emergency brake question again.
If my memory is right the Narrow space goes toward the carrier .See that ledge it has some wear on it in picture number 1 . So you have the pins the wrong way round , I believe the heads of the pins go toward the car, cotter pins visible when you take off the drum .
Hope this helps John Cochran |
06-28-2014, 05:26 PM | #3 |
In the first picture, the top side goes against the carrier. That's why the bracket is offset for the pin clearance. The offset rides on the carrier.
06-28-2014, 05:59 PM | #4 |
Fred, I can never remember this stuff either. Whenever I take my brakes apart, I take a picture of the setup before I disassemble it.
06-28-2014, 08:25 PM | #5 | |
Guess I am still confused a bit and having a tuff time figuring out where I am messing up. I may have to get a local "expert" to come over and give me a hand or I could take the right drum off the huckster and see how it is put together (but I am lazy but may have to do that).
Fred Kroon 1929 Std Coupe 1929 Huckster |
06-28-2014, 08:28 PM | #6 | |
Ray who in our club is the brake expert?
06-28-2014, 10:03 PM | #7 |
Fred, I don't know anyone who might be an expert, but I think we have a dvd or vhs on brake rebuilding in our club library. Call Patty Brost and ask her about those.
06-28-2014, 10:18 PM | #8 | |
06-29-2014, 10:11 AM | #9 |
Is Service Bulletins page 264 of any help ?
06-29-2014, 10:33 AM | #10 | |
Mike, The pin heads face out, (cotter pins in toward carrier. The image is correct as shown for the passenger (right) side. The toggle lever pin head must face to the outside as well when installed. Make sure the band is seated correctly on the carrier on the steel pads as Tom noted in his reply. Both springs installed and the actuating springs installed on the outer lever/e-brake shaft. I have done many brake jobs. Those that replied about taking reference photos before they disassemble... that's fine, but more times than not head/pins/ roller tracks, etc are more incorrect than correct when I disassemble. The absolute best self help training tool for a comprehensive brake overhaul is Lloyd Kerr's "How to stop on a dime". A comphrehensive brake job "restoring" all shafts/levers/pins/backing plates/drums, etc with proper rebuilding is 30-40 hours. Brakes are one of my specialties! Larry Shepard |
06-29-2014, 01:12 PM | #11 |
I found this picture on Epay, I don't know if they are right or not.
Bob |
06-29-2014, 04:18 PM | #12 |
Thanks guys. I will get back to trying to fix this thing. It could be that the band was not seated correctly like Tom mentioned. When I started taking off the band, it sort of click back into place. Plus the band seemed to have a rub spot on it on the side that seemed to be not seated correctly. I will have to give it a try in the A.M.
06-29-2014, 06:57 PM | #13 |
I think John may have hit on the correct problem. The attached pictures show wear on the inside of the cast iron drum. The one picture shows the ring all the way around the drum and the other shows a close up of the grove worn in the drum. So it looks like the e brake band was rubbing on the drum. Also it shows a little rubbing of the service brake band.
So like mentioned on my prior post on this problem, where someone mentioned maybe the axle was worn, this could be what the problem is. Question I have is would putting a axle shim on the axle between the axle and the hub stop this?
07-05-2014, 03:05 PM | #14 |
Just thought some of you may be interested as to what I found to be the problem with my E brake situation. It was a worn hub that was causing me the problem.
With suggestion of Larry I did check out the inside of the hub. It had spots in the inside where it looked like it may have rusted at one time and some of the metal was missing. I put in one axle shim and tired it but it still rubbed a little. So now I have two shims in it and I think that will do the job. So I think I have at least a temporary fix on this problem but I think I may start looking for another used 29 hub. Thanks again guys for all the help and especially Larry who gave me a call which got me on the right track/
