12-05-2019, 08:02 PM | #1 |
Gas and ways to seal
Hi gents
I’m having difficulty sealing the fuel connection into carb. I know Teflon tape is no good. Can I use seal all? Or what do you recommend?
Thanks - 30-9 1939, 1940 |
12-05-2019, 08:07 PM | #2 |
Re: Gas and ways to seal
How about GOOD threads? It may require a different carburetor cover (top plate). They are plentiful and cheap.
12-05-2019, 09:01 PM | #3 |
Threads don't seal it. Depending on the application, the flare or ferrule does the sealing. The threads provide pressure for the seal.
12-05-2019, 10:24 PM | #4 |
I have tinned the sealing part with solder
12-05-2019, 10:51 PM | #5 |
