02-14-2016, 05:32 PM | #1 |
12 volts to a 6 volt starter?
Installed the stock 6 volt starter on the so-far unstarted rebuilt 221 today. Charged the battery and the engine is pretty tight so the starter is fignting to turn it over. Can I jump at 12 volt battery directly to the 6 volt starter to get some umph without damaging the starter? That is, one jumper cable end to the terminal lug on the starter and the other cable end to the engine block?
02-14-2016, 05:37 PM | #2 |
Re: 12 volts to a 6 volt starter?
Yes....
02-14-2016, 06:26 PM | #3 |
Are you using the correct cables designed for 6 volts or do you have cables designed for 12 volts. That could be your problem.
Charlie Stephens |
02-14-2016, 06:32 PM | #4 |
Besides checking that you have 6 volt cables, it could also be paint on the freshly rebuilt engine block.
After my rebuild I had to scrape paint off of the block where the ground strap connected to it, and where the starter mates to the block. Cranked over nicely after doing that. |
02-14-2016, 06:38 PM | #5 | |
02-15-2016, 09:35 AM | #6 |
glass of MMO or thin oil in all of the cylinders. Screw a mechanical oil pressure gauge in the pressure port on the left rear of the engine. Put a rag over the plug holes so you don't have a big mess. Spin the engine with 12 volts hooked up as you described. The pressure you see on the gauge will be what you will see driving at 40 MPH. I want to see 45 lbs or slightly higher. The advantage is you can adjust the oil pressure before installing the engine. If the pressure is low I can instruct you on how to increase it. Most low oil pressure is due to a weak or short spring in the front pressure bypass valve or in the oil pump itself if it is a later style pump. If it has a later pump I screw the pressure adjustment in so it opens at about 55 lbs leaving the front valve in the intake manifold to make the adjustment. Leaving the front valve to do the pressure release also dumps more oil on the timing gears and more oil to the water pumps that are oil lubricated. G.M.
www.fordcollector.com |
02-15-2016, 09:43 AM | #7 |
When I recently fired up my 42 Merc engine, the old 6-volt starter just didn't have enough power to turn it over fast enough. So, I did as you mentioned . . . switched over to 12 volts, ran it with the plugs out - got good oil pressure, put the plugs back in and fired the engine.
I have a magneto, so I didn't need 6V at all. Once the engine was initially broken in, then I switched back to a 6V starter. I noticed that my starter just didn't turn the engine over that well (too slow), so I had the starter rebuilt by a reputable firm here in Columbus - now it turns over nicely and the engine has no problem starting. With a mag, you need some rpm to generate enough juice to fire the plugs efficiently . . . so this really helped. Note: I used to run my flathead 6V starters on 12V for the long haul - I never had issues, but some folks have bendix problems due to the force at which 12V slams the bendix into the flywheel. Things like bendix springs breaking, etc.. Just something for others to think about . . . |
