Old 07-29-2013, 01:26 PM   #1
HOTRODSURFER
HOTRODSURFER's Avatar
Default vin plate location 48 ford
I just purchased this 48 for coupe -where is the vin plate located??
HOILER AUTO REPAIR est 1918
https://www.facebook.com/pages/HOILER...16725868370435
HOTRODSURFER is offline   Reply With Quote
Old 07-29-2013, 01:54 PM   #2
Bruce Lancaster
Default Re: vin plate location 48 ford
Main serial number is on the transmission case at top of the bellhousing area...there is a covered slot with a bend-up piece near top center of the toeboard where you might be able to see it with a flashlight.
That number was the primary # in the Ford system, and was also copied to the top of the left front frame rail at assembly. If car is a V-8 it would look like *899A-2,XXX,XXX*...full prefix might not be on the frame.
Bruce Lancaster is offline   Reply With Quote
Old 07-29-2013, 02:01 PM   #3
Steves46
Steves46's Avatar
Nice looking car! Still has the Flattie?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 07-29-2013, 09:26 PM   #4
FLA48
FLA48's Avatar
Good looking car. As a note, if the transmission has been changed out, the numbers on it will not match the numbers stamped on the frame rail. The numbers on the frame are the ones that count.
FLA48 is offline   Reply With Quote
Old 07-30-2013, 05:34 AM   #5
HOTRODSURFER
yes it does !and will stay that way
Old 07-31-2013, 04:19 PM   #6
HOTRODSURFER
thanks for the help fellas!
Old 08-01-2013, 11:20 AM   #7
bigvince
If you have the original patent plate on the firewall, that will tell you where it was produced. There will be letters stamped into the aluminum. Mine has LB for Long Beach, CA
bigvince is offline   Reply With Quote
