Old 08-17-2023, 07:28 PM   #21
Synchro909
Synchro909's Avatar
Default Re: Brake Drums - Advice Regarding Their Use
Originally Posted by daveymc29 View Post
Following what another member of this forum did, I bought two rear brake arms and replaced the two fronts on my Coupe with the taller rears. I haven't tried to see how much better they are with a bunch of panic stops on rain slick fresh asphalt, but just ordinary everyday driving I have to admit the brakes do a better job of stopping the car and the few times I have hit them rather hard, the car slowed in a straight line, unlike the thrill that used to produce. so I'm inclined to think the stronger stopping power to the front is a good thing on my Coupe. Your results may vary. Not for Shw cars.
Davey, I'm glad you like the improvement.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-18-2023, 04:33 PM   #22
daveymc29
daveymc29's Avatar
Synchro Yes, and it isn't all that hard to do' I bought two bushings from a local hardware store to fill in the gap between the size of the front shafts and the rears. It was bronze and I did spin it and nearly broke a thumb, but I learned a little more attention to my work and a few drops of oil made for a safer hole drilling experience. Everything else was pretty straight forward and the outcome proved better than I had expected.
daveymc29 is offline   Reply With Quote
Old 08-18-2023, 07:45 PM   #23
Synchro909
Synchro909's Avatar
The idea of that change is to move the bias as much as possible towards the front wheels. It is only one of several changes I make. So far, I haven't locked either front nor back wheels since doing it. I figure I have the balance just about right.
Old 11-15-2023, 11:56 AM   #24
meteorpete
How can you tell the difference visually between an original steel drum and a cast drum? When were cast drums first available? Thanks
meteorpete is offline   Reply With Quote
Old 11-15-2023, 06:50 PM   #25
Synchro909
Synchro909's Avatar
If you look at the drums from the wheel side, steel ones have a rolled lip that looks hollow around the outside edge. The cats ones vary a bit but they all have a solid ring around the outside edge. You can tell the difference very easily.
Cast drums have been around for many years now - I don't know when the first ones appeared but our club was making them ....maybe 30 years ago.
Old 11-16-2023, 09:19 AM   #26
meteorpete
Great - thanks for the info!
Pete
