05-21-2020, 11:07 PM | #1 |
28 roadster frame vs 30 coupe frame
From what I've discovered through search and catalogs and what not, it appears they are at least dimensionally the same. Is that correct?
05-21-2020, 11:09 PM | #2 |
Re: 28 roadster frame vs 30 coupe frame
The height of the pads for the radiator is slightly different.
Charlie Stephens |
05-21-2020, 11:20 PM | #3 |
Perfect Thank you
05-21-2020, 11:24 PM | #4 |
The mechanical brake linkage will be different and the hand brake will be on the left for early '28. If you are doing a restoration the fender braces and running board brackets will be different. What is the whole project?
Charlie Stephens |
05-21-2020, 11:47 PM | #5 |
The handbrake is on the right on early right hand drive cars
05-21-2020, 11:52 PM | #6 |
05-22-2020, 03:45 PM | #7 |
One of our resident model A enthusiasts has very good research data that he put together for all to study. You will need adobe reader for the PDF files.
http://www.plucks329s.org/frame.htm |
