Old 07-18-2011, 05:44 PM   #1
jfcrash
jfcrash's Avatar
Default 1935 Rear Lamp Wiring Harness Routing
Need help on the routing of the 'rear lamp wiring assy 48-14405' (had none to begin with)......
Goes from fuel tank area...then?? (this is were I heed help)...picks up stop lite switch then forward to lighting harness...... but how??
The 35-36 book is not helping me...
Thanks
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 07-18-2011, 06:49 PM   #2
Mike in AZ
Mike in AZ's Avatar
Default Re: 1935 Rear Lamp Wiring Harness Routing
maybe this diagram will help??..good luck....Mike
http://www.vanpeltsales.com/FH_web/F...ram1936car.jpg
Mike in AZ is offline   Reply With Quote
Old 07-19-2011, 06:52 AM   #3
wamnram
wamnram's Avatar
Wires clip to inside bottome of frame flange. From gas tank runs along driver side inner frame rails. Wiring goes under frame where tranny mount is then back up into frame rail to brake light switch. Look close or zoom in on picture and you can see it where it goes under tranny mount. I think it shows this somewhere in the 35/36 book.
Wayne
wamnram is offline   Reply With Quote
Old 07-19-2011, 06:57 AM   #4
jfcrash
jfcrash's Avatar
Thanks Mike, I see that it is routed to the right of the battery, so I guess it is following the cross frame rail.......now I have to figure out which holes it went through in the X-box section without pinching the harness with the brake rods........
Thanks, Jim
jfc
Old 07-19-2011, 07:01 AM   #5
wamnram
wamnram's Avatar
jfc, it goes under the x-box section, not through any holes.
Wayne
Old 07-19-2011, 07:14 AM   #6
jfcrash
jfcrash's Avatar
Wamnran, guess your post came in as I was reponding to Mike,
looking at the 35/36 book now, it does show it going under the x box for 1936....but states in 1935 apperantly it went thru some particular holes in the x box which iis what I need to figure out....at least you have confirmed the routing from the fuel tank....I may just route it as in 36 rather than pinching the cable inside the x box...
Thanks, Jim
jfc
